[OpenLayers-Users] Error displaying map in IE8 - VML.js
Andreas Hocevar ahocevar at opengeo.org
Fri Jun 12 02:58:37 EDT 2009
On Fri, Jun 12, 2009 at 8:53 AM, Kenneth Skovhede, GEOGRAF
A/S<ks at geograf.dk> wrote:
> Note sure what the actual problem is, but there are notes that the patch
> does not solve all issues.
> There is a nother fix mentioned, namely the one in comment #20:
> http://trac.openlayers.org/ticket/1910#comment:20
> This effectively places IE8 in IE7 compatibility mode, and it works.
> Although it's not the correct long term solution, you can use it until
> the issue is fixed more permanently.
The latest patch [1] should fix all vector layer issues in IE8. It
would be nice to get some feedback if this is really the case.
Regards,
Andreas.
[1] http://trac.openlayers.org/attachment/ticket/1910/openlayers-1910.patch
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
