[OpenLayers-Users] NavToolBar events
Andreas Hocevar
ahocevar at opengeo.org
Fri Jun 12 04:29:57 EDT 2009
On Fri, Jun 12, 2009 at 9:11 AM, Brad Spencer<brad at cubewerx.com.au> wrote:
> A little more explanation, I use doubleclick for picking polygons
> interactively and drag-mouse-shift for picking a whole bunch within a drag
> area in my 'select mode'. The user can switch to viewing mode via my mode
> toggle button and happily use the default alternatives. However, if they do
> not consciously toggle off the select mode and hit the mouse-zoom button (of
> the OpenLayers.Control.NavToolbar fame) instead, the defaults are
> automatically restored and I am unable to pop my toggle button to keep in
> sync with the functionality.
Oh, now I see. I had entirely forgotten about Control.NavToolbar
because I never use that one. When I need functionality like yours, I
create a custom Control.Panel and add a button for a
Control.Navigation there. This will then work without taking extra
care. You have to be aware that Control.NavToolbar is also just a
Control.Panel. But see below for a solution for your original
question.
> I will have a look at the movend/zoomend but I will not be able to pop my
> button until they do some map navigation therefore the button will be
> incorrectly set during that period. However, I can make sure that the button
> does not pop when doing panning and zooming in select mode by setting a
> status flag, so I think it work that way just fine.
> What I would really like is an event triggered when the user hits the
> mouse-zoom button. Then I could pop my button immediately highlighting to
> the user that they are now in viewing mode.
You can do that already:
var control = new OpenLayers.Control.NavToolbar();
// controls[0] is the Navigation control inside the NavToolbar
control.controls[0].events.on({
"activate": function() {
// deactivate your select mode here
I think this should help now.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
