[OpenLayers-Users] getDataExtent() only working on part of data of layer
Andreas Hocevar ahocevar at opengeo.org
Fri Jun 12 06:41:48 EDT 2009
Hi Jan,
please post to the list instead of sending a mail to a developer directly.
I gave you a wrong setExtent function. The correct function should look
like this:
var setExtent = function() {
     if(dataExtent) {
         dataExtent.extend(this.getDataExtent());
     } else {
         dataExtent = this.getDataExtent();
     map.zoomToExtent(dataExtent);
What was wrong? OpenLayers.Bounds::extend does not return the new
extent, it modifies the Bounds object it was used on. My bad, sorry for
the confusion.
Regards,
Andreas.
Jan Martin wrote:
> Hi Andreas,
> seems this isn't as easy as I thought.
> Still not working.
> Please find the whole folder containing all files as a .zip.
> Jan
> On Thu, Jun 11, 2009 at 7:41 PM, Andreas Hocevar <ahocevar at opengeo.org
> <mailto:ahocevar at opengeo.org>> wrote:
>     Hi Jan,
>     On Thu, Jun 11, 2009 at 6:49 PM, Jan
>     Martin<janmartin3 at googlemail.com <mailto:janmartin3 at googlemail.com>>
>     wrote:
>      > Hi Andreas,
>      > thanks for your help.
>      > I hope I changed my file right, but unfortunately its not working:
>      > http://mybestprojects.com/data/test5/test5.html
>     Sorry, my bad. Wrong setExtent function. Please change to
>      dataExtent = dataExtent ? this.getDataExtent().extend(dataExtent) :
>      > Also I have no clue how to implement Format.GPX::read
>      > There are no results of anybody using it  when googling for it.
>      > Can't be can it?
>     OpernLayers.Format.* classes have a read method. This can be used to
>     read features from data files. But no need to bother, with the above
>     fix your app should work.
>     Regards,
>     Andreas.
>      > Jan
>      > On Thu, Jun 11, 2009 at 6:07 PM, Andreas Hocevar
>     <ahocevar at opengeo.org <mailto:ahocevar at opengeo.org>>
>      > wrote:
>      >> Hi Jan,
>      >> one more thing that came to my mind: are you aware that you are
>      >> working with two layers here? From what you wrote, it seems you
>     think
>      >> that you have one layer lgpx. But in fact you have two, you just use
>      >> the same variable for both.
>      >> You could also solve your problem with just one layer, but then you
>      >> would have to use Format.GPX::read to get the features from both
>     urls.
>      >> You would also have to take care to style the features properly (red
>      >> from one url, green from the other).
>      >> I guess the way you chose is simpler, you just have to be aware that
>      >> you are working with two layers.
>      >> Regards,
>      >> Andreas.
>      >> On Thu, Jun 11, 2009 at 5:55 PM, Andreas
>     Hocevar<ahocevar at opengeo.org <mailto:ahocevar at opengeo.org>>
>      >> wrote:
>      >> > Hi Jan,
>      >> > On Thu, Jun 11, 2009 at 5:20 PM, Jan
>      >> > wrote:
>      >> >> Hi all,
>      >> >> right now getDataExtent() only considers the data added LAST
>     (red).
>      >> >> But I need the map to zoom in on ALL data in lgpx (green AND
>     red).
>      >> >> What's my error?
>      >> > you need to take into account the dataExtent of both layers:
>      >> > var dataExtent;
>      >> >   dataExtent = dataExtent ? this.getDataExtent() :
>      >> > this.getDataExtent().extend(dataExtent);
>      >> > lgpx = new OpenLayers.Layer.GML
>      >> > ("green","separated/20090607172151.gpx",{
>      >> >     projection: new  OpenLayers.Projection("EPSG:4326"),
>      >> >     style: {strokeColor: "green", strokeWidth: 5,
>     strokeOpacity: 0.8},
>      >> >     format: OpenLayers.Format.GPX,});
>      >> > lgpx.events.register("loadend", lgpx, setExtent);
>      >> > map.addLayer(lgpx);
>      >> > ("red","separated/20090607110550.gpx",{
>      >> >     style: {strokeColor: "red", strokeWidth: 5, strokeOpacity:
>     0.8},
>      >> > map.addLayer(lgpx);
>      >> > Regards,
>      >> > Andreas.
>      >> Andreas Hocevar
>      >> OpenGeo - http://opengeo.org/
>      >> Expert service straight from the developers.
>      >> _______________________________________________
>      >> Users mailing list
>      >> Users at openlayers.org <mailto:Users at openlayers.org>
>      >> http://openlayers.org/mailman/listinfo/users
>      > Users mailing list
>     Andreas Hocevar
Andreas Hocevar
