[OpenLayers-Users] Error displaying map in IE8 - VML.js
Christopher Schmidt crschmidt at metacarta.com
Fri Jun 12 10:01:47 EDT 2009
On Fri, Jun 12, 2009 at 03:52:54PM +0200, Asle Benoni wrote:
> Thanks Kenneth, the compatibility hack works fine. I would rather not hack
> VML.js but I see this hack is newer than the one I tried. As long as the
> quickfix works I am satisfied. But would like to know if some have success
> with it and if it is included in future OL release.
It can't be included in a future OL release until people test it. If
you're unwilling to test it, the chances it will be included decrease.
Please help test it if you care about it.
-- Chris
> /asle
> 2009/6/12 Andreas Hocevar <ahocevar at opengeo.org>
> > Hi,
> > On Fri, Jun 12, 2009 at 8:53 AM, Kenneth Skovhede, GEOGRAF
> > A/S<ks at geograf.dk> wrote:
> > > Note sure what the actual problem is, but there are notes that the patch
> > > does not solve all issues.
> > > There is a nother fix mentioned, namely the one in comment #20:
> > > http://trac.openlayers.org/ticket/1910#comment:20
> > > This effectively places IE8 in IE7 compatibility mode, and it works.
> > > Although it's not the correct long term solution, you can use it until
> > > the issue is fixed more permanently.
> > The latest patch [1] should fix all vector layer issues in IE8. It
> > would be nice to get some feedback if this is really the case.
> > Regards,
> > Andreas.
> > [1]
> > http://trac.openlayers.org/attachment/ticket/1910/openlayers-1910.patch
> > Andreas Hocevar
> > OpenGeo - http://opengeo.org/
> > Expert service straight from the developers.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
