[OpenLayers-Users] selecting marker potential bug
Chris Abraham
cabraham at openplans.org
Fri Jun 12 14:48:40 EDT 2009
Alternatively, you can replace lines 69-71 with:
styleMap: new OpenLayers.StyleMap(
style
I assume here that since I didn't specify "default" this "style" gets
set to all options.
Chris
On Jun 12, 2009, at 2:19 PM, Chris Abraham wrote:
> Hi,
> I think I have found a bug. See attached file for a simple test case.
> When you click on one of the points (features) a popup will
> display. Since the feature is selected, it's style changes and it
> turns blue. This is unexpected. I would have expected it to keep
> the default style, that is, for it not to change in appearance. Is
> this the desired behavior. To prevent the appearance change, you
> can change line 71 to:
> "default": style, "select": style
> Please let me know if this is a bug or not.
> Also, it may be related to this bug http://trac.openlayers.org/
> ticket/1498.
> Thanks,
> Chris
> <clusteringbug.html>_______________________________________________
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
