[OpenLayers-Users] Map not showing in IE6 & IE7, FF, Safari and Chrome are fine
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Jun 16 06:36:52 EDT 2009
It means there is an error in test_ie2.html line 690.
Most likely there is an invalid object initialization:
x: 0,
y: 0, <-- IE breaks, FF ignores comma
Regards, Kenneth Skovhede, GEOGRAF A/S
sendeman skrev:
> Hi All,
> I have a test site for a mapping application I'm building. Depending on the
> map I'm trying to serve, I have trouble displaying my map in IE6 and IE7.
> The map that is giving issues when I try to display it in IE contains a
> single WMS layer that is served by my own Mapserver. When I use a WMS layer
> from somewhere else, IE displays it just fine. Apparently IE doesn't like my
> init() function. I tried to use  http://getfirebug.com/lite.html Firebug
> Lite  to find my error, but this hasn't helped me thus far. It gives this
> message in the console:
> "'undefined' is empty or not an object (test_ie2.html,690)" (this was
> translated from me by Dutch)
> test_ie2.html is the name of test site. I don't know what the 690 means. Is
> that the line number in the openlayers.js? I checked that line number, but
> couldn't make sense of it (no js guru ;-)  ).
> For this map, in IE I only get a layerswitcher that is empty and a zoombar
> that with zero (?) length. No maptiles are rendered. In Firefox, Google
> Chrome and Safari, the map is displayed as it should be.
> Like I said, the online WMS map displays just fine in IE too.
> I hope the above illustrates the problem I have. I've added the code of the
> working file, that uses an online WMS map and of the file that I'm using to
> display my mapserver map, which doesn't work in IE.
> Any ideas on what I can do to let IE play along? It might just be some
> syntax error that the other browsers allow and IE doesn't? It might be
> anything else though.... :-) Any help will be greatly appreciated!
> Best regards,
> Martijn Senden.
> _________________________________________________________
> Code of working online WMS map:
> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN"
> "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
> <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"><head>
> <title>Untitled</title>
> <style type="text/css">
> body,
> html {
> 	overflow: hidden;
> 	height: 100%;
> #map {
> 	position: absolute;
> 	z-index:1;
> 	top: 100px;
> 	bottom: 50px;
> 	left: 0;
> 	width: 70%;
> 	border: 1px solid black;
> 	background: red;
> </style>
> <!--[if lte IE 8]>
> #map {
> 	bottom: auto;
> 	height: expression(document.documentElement.clientHeight - 150 +"px");
> </style>
> <![endif]-->
> <script type="text/javascript"
> src="http://openlayers.org/api/OpenLayers.js"></script>
> <script type="text/javascript">
> var lon = 5;
> var lat = 40;
> var zoom = 5;
> var map, layer;
> function init(){
> 	map = new OpenLayers.Map('map', {theme: null});
> 	layer = new OpenLayers.Layer.WMS(
> 		"OpenLayers WMS",
> 		"http://labs.metacarta.com/wms/vmap0",
> 		{layers: "basic"}
> 	map.addLayer(layer);
> 	vlayer = new OpenLayers.Layer.Vector( "Editable" );
> 	map.addLayer(vlayer);
> 	var container = document.getElementById("panel");
> 	var panel = new OpenLayers.Control.EditingToolbar(vlayer, {div:
> container});
> 	map.addControl(panel);
> 	map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
> window.onload=init;
> </script>
> </head><body>
> <div id="map"></div>
> </body></html>
> Code of my own mapserver map, which is broken in IE:
> body,
> html {
> 	overflow: hidden;
> 	height: 100%;
> #map {
> 	position: absolute;
> 	z-index:1;
> 	top: 100px;
> 	bottom: 50px;
> 	left: 0;
> 	width: 70%;
> 	background: red;
> </style>
> <!--[if lte IE 8]>
> #map {
> 	bottom: auto;
> </style>
> <![endif]-->
> function init(){
>   //Create a new OpenLayers mapwindow with associated controls
>   var map = new OpenLayers.Map('map', {
> 		projection: "EPSG:28992",
> 		maxResolution: 1328.125,
> 		numZoomLevels: 14,
> 		maxExtent : new OpenLayers.Bounds(-23500,289000,316500,629000),
> 		restrictedExtent: new OpenLayers.Bounds(80000,442000,88000,452000),
> 		units : "meters",
> 		controls: [
> 			new OpenLayers.Control.ZoomToMaxExtent(),
> 			new OpenLayers.Control.PanZoomBar({zoomWorldIcon: true}),
> 			new OpenLayers.Control.LayerSwitcher({'ascending':false}),
> 			new OpenLayers.Control.MousePosition(),
> 			new OpenLayers.Control.MouseDefaults(),
> 			new OpenLayers.Control.KeyboardDefaults(),
>   // Add Spoortunnel Delft Mapserver .map-files
>   layer = new OpenLayers.Layer.MapServer( "Topografie",
>           "/geoviewerbin/mapserv.exe", {map:
> "c:/OSGeo4W/apps/geoviewer/maps/spoortunnel.map", layers: "Topografie"} );
>   map.zoomToExtent(new OpenLayers.Bounds(83600,446000,84600,448200));
>   // Add a permanent link to the current view
>   map.addControl(new OpenLayers.Control.Permalink() );
> window.onload=init;
> </script>
> </head><body>
> </body></html>
