[OpenLayers-Users] Scalebar not visible
sendeman
martijnsendenspam at gmail.com
Tue Jun 16 10:08:45 EDT 2009
Hi all!
I'm trying to add a scalebar to my mapserver + openlayers webapp. I tried
implementing
http://dev.openlayers.org/addins/scalebar/trunk/examples/scalebar.html the
online example into my own page, but until now, I haven't succeeded. I used
firebug to see the generated source and the javascript does add divs for the
scalebar, I just don't see it anywhere. I have made no changes to the css or
javascript, just changed the location and filename. The src values of the
scripts and href of the linked stylesheet are correct.
I added the code I used below.
Does anyone see what's going wrong? Because I don't. :-)
Thanks in advance, any help will be greatly appreciated!
Best regards,
Martijn Senden.
_________________________________________________________________
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN"
"http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"><head>
<title>Untitled</title>
<style type="text/css">
body,
html {
overflow: hidden;
height: 100%;
#map {
position: absolute;
z-index:1;
top: 100px;
bottom: 50px;
left: 0;
width: 70%;
/* height:80%; */
border: 1px solid black;
background: red;
#scalebar {
position: absolute;
right: 0;
bottom: 50px;
width: 25%;
height: 200px;
border: 1px solid #000;
</style>
<!--[if lte IE 8]>
#map {
bottom: auto;
height: expression(document.documentElement.clientHeight - 150 +"px");
</style>
<![endif]-->
<script type="text/javascript"
src="http://openlayers.org/api/OpenLayers.js"></script>
src="javascript/openlayers_scalebar.js"></script>
<link href="css/scalebar.css" rel="stylesheet" type="text/css"
media="screen">
<script type="text/javascript">
function init(){
//Create a new OpenLayers mapwindow with associated controls
var map = new OpenLayers.Map('map', {
projection: "EPSG:28992",
maxResolution: 1328.125,
numZoomLevels: 14,
maxExtent : new OpenLayers.Bounds(-23500,289000,316500,629000),
restrictedExtent: new OpenLayers.Bounds(80000,442000,88000,452000),
units : "meters",
controls: [
new OpenLayers.Control.ZoomToMaxExtent(),
new OpenLayers.Control.PanZoomBar({zoomWorldIcon: true}),
new OpenLayers.Control.LayerSwitcher({'ascending':false}),
new OpenLayers.Control.MouseDefaults(),
new OpenLayers.Control.KeyboardDefaults()
// Add Spoortunnel Delft Mapserver .map-files
layer = new OpenLayers.Layer.MapServer( "Topografie",
"/geoviewerbin/mapserv.exe", {map:
"c:/OSGeo4W/apps/geoviewer/maps/spoortunnel.map", layers: "Topografie"} );
map.addLayer(layer);
//Add a scalebar to the map
scalebar = new OpenLayers.Control.ScaleBar();
map.addControl(scalebar);
map.zoomToExtent(new OpenLayers.Bounds(83600,446000,84600,448200));
window.onload=init;
</script>
</head><body>
<div id="map"></div>
</body></html>
View this message in context: http://n2.nabble.com/Scalebar-not-visible-tp3086564p3086564.html
