[OpenLayers-Users] Informations by onmouseover / alternative to WFS?
Kai Behncke Kai-Behncke at gmx.de
Tue Jun 16 10:35:08 EDT 2009
Hi Bart,
thank you for that hint.
I have got it to run with the wms/wfs of
layer = new OpenLayers.Layer.WMS(
"States WMS/WFS",
"http://demo.opengeo.org/geoserver/ows",
{layers: 'topp:states', format: 'image/gif'}
but I had no luck so far with my own wms/wfs.
I use MapServer 5.4 and I have build also ONE mapfile that works as WMS AND WFS.
If I do a mouseover on the areas I can see in firebug that the wfs is recognised, I get back e.g.
<?xml version='1.0' encoding="ISO-8859-1" ?>
<wfs:FeatureCollection
   xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
   xmlns:gml="http://www.opengis.net/gml"
   xmlns:wfs="http://www.opengis.net/wfs"
   xmlns:ogc="http://www.opengis.net/ogc"
   xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
   xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver http://www.tourismus-maps.de/cgi-bin/mapserv54
?map=/home/promotion/behncke/gastronomap_wms/gastronomap_wms.map&amp;SERVICE=WFS&amp;VERSION=1.1.0&amp
;REQUEST=DescribeFeatureType&amp;TYPENAME=gastronomie_ows&amp;OUTPUTFORMAT=text/xml; subtype=gml/3.1
.1  http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
      <gml:boundedBy>
      	<gml:Envelope srsName="EPSG:4326">
      		<gml:lowerCorner>8.018902 52.293344</gml:lowerCorner>
      		<gml:upperCorner>8.022836 52.296208</gml:upperCorner>
      	</gml:Envelope>
      </gml:boundedBy>
    <gml:featureMember>
      <ms:gastronomie_ows gml:id="gastronomie_ows.7798543.000">
        <gml:boundedBy>
        	</gml:Envelope>
        </gml:boundedBy>
        <ms:msGeometry>
          <gml:Polygon srsName="EPSG:4326">
            <gml:exterior>
              <gml:LinearRing>
                <gml:posList srsDimension="2">8.020861 52.296208 8.020993 52.295888 8.020546 52.295777
 8.020815 52.294923 8.020891 52.294862 8.022112 52.294918 8.022827 52.294175 8.022655 52.294036 8.022836
 52.293747 8.022221 52.293344 8.019422 52.294743 8.018902 52.295672 8.020861 52.296208 </gml:posList
              </gml:LinearRing>
            </gml:exterior>
          </gml:Polygon>
        </ms:msGeometry>
        <ms:osm_id>7798543.000</ms:osm_id>
        <ms:name></ms:name>
        <ms:type>forest</ms:type>
      </ms:gastronomie_ows>
    </gml:featureMember>
</wfs:FeatureCollection>
.....but the hovering/highlighting does not work.
Has anybody an idea why this can be?
Do I need any special entries in the Mapfile?
The typical WMS/WFS-requests work fine so far.
Thank you very much, Kai
-------- Original-Nachricht --------
> Datum: Mon, 15 Jun 2009 11:19:53 +0200 (CEST)
> Von: bartvde at osgis.nl
> An: "Kai Behncke" <Kai-Behncke at gmx.de>
> CC: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Informations by onmouseover / alternative      to WFS?
> I would try and use:
> OpenLayers.Control.GetFeature
> examples\getfeature-wfs.html
> Best regards,
> Bart
> > Dear users,
> > I have an application where I load in 500 pois via WFS, by onmouseover
> > some informations to that points are shown.
> > Obviously that application is quite slow (e.g. in Internet Explorer it
> is
> > far too slow).
> > Is there an alternative to WFS doing a mouseover with 500 pois?
> > What would you recommend?
> > GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
> > Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
GMX FreeDSL Komplettanschluss mit DSL 6.000 Flatrate und Telefonanschluss
für nur 17,95 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
