[OpenLayers-Users] Ticket #2080, Optical zoom bug
Swärd Mårten
marten.sward at smhi.se
Wed Jun 17 01:36:46 EDT 2009
Hi
Thanks for the reply! I know that the problem is in IE7 and not a bug specific to OL, but it's quite critical for us to make a "workaround" for this. So my hope was that it would be possible to somehow fix this "Bill Gates bug" by adjusting some code I OL.. The problem is that I (we) don't know which part of the OL code that this IE7-bug affects so it's a bit difficult to try out some workarounds..
Do you, or anyone, know wich classes this IE7 bug affects?
Best regards, Mårten
-----Ursprungligt meddelande-----
Från: andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] För Andreas Hocevar
Skickat: den 16 juni 2009 14:19
Till: Swärd Mårten
Kopia: users at openlayers.org
Ämne: Re: [OpenLayers-Users] Ticket #2080, Optical zoom bug
Hi Mårten,
the problem is that page zooming in IE7 is somewhat broken. If you
google for IE7 and page-zoom, you will find several sources reporting
a similar issue, none with a solution unfortunately (e.g. [1]).
The good news is: in IE8 it works fine.
Regards,
Andreas.
[1] http://www.yui-ext.com/forum/showthread.php?t=38454
On Tue, Jun 16, 2009 at 1:03 PM, Swärd Mårten<marten.sward at smhi.se> wrote:
> Hello folks!
> I have a problem with an application when using IE7, the problem is exaktly
> as described in ticket 2080, http://trac.openlayers.org/ticket/2080
> Does anyone know what causes this and could point me to a direction where to
> start searching for a solution?
> Any information that can narrow down the search would be appreciated...
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
