[OpenLayers-Users] KML and area colorization
Andreas Hocevar ahocevar at opengeo.org
Wed Jun 17 10:31:53 EDT 2009
On Wed, Jun 17, 2009 at 3:36 PM, VIDAUD
Romain<RVIDAUD at atmo-rhonealpes.org> wrote:
> When I make the sample page you gave deserialize my kml (copy paste content of kml file) everything is ok. When I use a "Layer.Vector" version, the zone is displayed and colorized but not on a good geographic location (under IE7) ..
> The script is :
> new OpenLayers.Layer.Vector("KML", {
>                        protocol: new OpenLayers.Protocol.HTTP({
>                            url: kmladress,
>                            format: new OpenLayers.Format.KML({
>                                extractStyles: true,
>                                extractAttributes: true
You should configure a strategy with your layer:
        url: kmladress,
    strategies: [new OpenLayers.Strategy.Fixed()]
Intersting how your application works at all without it, but the
strategy will definitely take care of reprojecting your features to
the map's projection.
Regards,
Andreas.
> And I get as a result what can be viewed at
> http://www4.atmo-rhonealpes.org/site/OL_httpKML_layer.PNG (can give an real sample url cause it's on developpement server for now)
> Thanks,
> Romain
> -----Message d'origine-----
> De : andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] De la part de Andreas Hocevar Envoyé : mardi 16 juin 2009 16:23 À : VIDAUD Romain Cc : users at openlayers.org Objet : Re: [OpenLayers-Users] KML and area colorization
> Hi,
> this issue is fixed in OpenLayers 2.8 (currently available as 2.8-rc6 under http://www.openlayers.org/api/2.8-rc6/OpenLayers.js).
> To verify, go to
> http://www.openlayers.org/dev/examples/vector-formats.html, select "KML" as format, paste the contents of your kml there, and hit "add feature".
> Regards,
> Andreas.
> On Mon, Jun 15, 2009 at 6:02 PM, VIDAUD
>> Hello,
>> I have a KML problem under IE7. I am drawing areas providing OL a KML
>> file generated by my webserver.
>> Under Chrome and FF (and google earth when I download it) all is
>> correctly drawn and colorized, but with IE7, areas doesn't always have
>> their correct color (left white instead). Is there a known issue about it ?
>> (use example can be viewed at
>> http://www4.atmo-rhonealpes.org/Site/Map/ChargerModule/161505/194/0/1)
>> (KML file address is:
>> http://www4.atmo-rhonealpes.org/Site/Indice/KML/IndiceConfigPREVISIO/1
>> 5-06-2009/all)
>> Thanks,
>> Romain VIDAUD
>> Webmaster
>> Atmo-RhôneAlpes
>> Groupement d'Intérêt Economique d'Associations
>> Agréées pour la Surveillance de la Qualité de l'Air
>> AMPASEL - ASCOPARG - ATMO Drôme Ardèche - COPARLY - SUP'AIR
>> Standard : 04 38 49 92 20 - contact at atmo-rhonealpes.org
>> Info air: www.atmo-rhonealpes.org - 0810 800 710 (N° azur - Prix d'un
>> appel
>> local)
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
Andreas Hocevar
