[OpenLayers-Users] MapServer Layer for ECW creating blank tiles
soatley shawn at niagarafalls.ca
Wed Jun 17 11:43:13 EDT 2009
Chris, thanks for that tip.  It really helps me to troubleshoot it.  I think
I have figured out the problem, but not sure how to fix it.
Now that it is sending WMS requests, I can see the url and compare it to my
other vector tiles.  The problem is that the WMS requests are going out with
Lat/Long values.  When I converted the BBOX value to UTM it rendered
perfectly.
My question is how can I do this using OL?  Can I have that layer request
coordinates in UTM (17N) so that the URL hitting MapServer already has the
value?
Thanks again,
Shawn
Christopher Schmidt-2 wrote:
> Instead of using a MapServer layer, instead add the following to your
> mapfile:
>   web
>     metadata
>       wms_srs "EPSG:4326"
>     end
>   end
> If your OpenLayers Map is in a different projection, use
> EPSG:ThatProjection instead.
> Then, change "MapServer" above to "WMS" (nothing else) and see where you
> can get. I think you're likely dealing with a projection issue, and the
> WMS layer will make it easier to debug.
> -- Chris
View this message in context: http://n2.nabble.com/MapServer-Layer-for-ECW-creating-blank-tiles-tp3092922p3093597.html
