[OpenLayers-Users] KML and area colorization
Andreas Hocevar
ahocevar at opengeo.org
Wed Jun 17 12:11:42 EDT 2009
Hi Romain,
I think there is something else wrong with your code. What makes me
suspicious is that you saw anything at all, because using vector
behaviors requires not only a protocol, but at least one strategy.
Looking at your screenshot, it also seems that you have not installed
OpenLayers right (images are missing). You do not just need to update
OpenLayers.js, but also the img and theme folders.
Regards,
Andreas.
On Wed, Jun 17, 2009 at 5:28 PM, VIDAUD
Romain<RVIDAUD at atmo-rhonealpes.org> wrote:
> Hi,
> Unfortunately i had tested the strategie parameter (as shown in examples on the OL website) and it does not help.. why http provided KML file would not react the same in IE and FF ?
> Romain
> -----Message d'origine-----
> De : andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] De la part de Andreas Hocevar
> Envoyé : mercredi 17 juin 2009 16:32
> À : VIDAUD Romain
> Cc : users at openlayers.org
> Objet : Re: [OpenLayers-Users] KML and area colorization
> Hi,
> On Wed, Jun 17, 2009 at 3:36 PM, VIDAUD
>> When I make the sample page you gave deserialize my kml (copy paste content of kml file) everything is ok. When I use a "Layer.Vector" version, the zone is displayed and colorized but not on a good geographic location (under IE7) ..
>> The script is :
>> new OpenLayers.Layer.Vector("KML", {
>> protocol: new OpenLayers.Protocol.HTTP({
>> url: kmladress,
>> format: new OpenLayers.Format.KML({
>> extractStyles: true,
>> extractAttributes: true
> You should configure a strategy with your layer:
> url: kmladress,
> strategies: [new OpenLayers.Strategy.Fixed()]
> Intersting how your application works at all without it, but the
> strategy will definitely take care of reprojecting your features to
> the map's projection.
> Regards,
> Andreas.
>> And I get as a result what can be viewed at
>> http://www4.atmo-rhonealpes.org/site/OL_httpKML_layer.PNG (can give an real sample url cause it's on developpement server for now)
>> Thanks,
>> Romain
>> De : andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] De la part de Andreas Hocevar Envoyé : mardi 16 juin 2009 16:23 À : VIDAUD Romain Cc : users at openlayers.org Objet : Re: [OpenLayers-Users] KML and area colorization
>> Hi,
>> this issue is fixed in OpenLayers 2.8 (currently available as 2.8-rc6 under http://www.openlayers.org/api/2.8-rc6/OpenLayers.js).
>> To verify, go to
>> http://www.openlayers.org/dev/examples/vector-formats.html, select "KML" as format, paste the contents of your kml there, and hit "add feature".
>> Regards,
>> Andreas.
>> On Mon, Jun 15, 2009 at 6:02 PM, VIDAUD
>>> Hello,
>>> I have a KML problem under IE7. I am drawing areas providing OL a KML
>>> file generated by my webserver.
>>> Under Chrome and FF (and google earth when I download it) all is
>>> correctly drawn and colorized, but with IE7, areas doesn't always have
>>> their correct color (left white instead). Is there a known issue about it ?
>>> (use example can be viewed at
>>> http://www4.atmo-rhonealpes.org/Site/Map/ChargerModule/161505/194/0/1)
>>> (KML file address is:
>>> http://www4.atmo-rhonealpes.org/Site/Indice/KML/IndiceConfigPREVISIO/1
>>> 5-06-2009/all)
>>> Thanks,
>>> Romain VIDAUD
>>> Webmaster
>>> Atmo-RhôneAlpes
>>> Groupement d'Intérêt Economique d'Associations
>>> Agréées pour la Surveillance de la Qualité de l'Air
>>> AMPASEL - ASCOPARG - ATMO Drôme Ardèche - COPARLY - SUP'AIR
>>> Standard : 04 38 49 92 20 - contact at atmo-rhonealpes.org
>>> Info air: www.atmo-rhonealpes.org - 0810 800 710 (N° azur - Prix d'un
>>> appel
>>> local)
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
>> Users mailing list
> Andreas Hocevar
> Users mailing list
Andreas Hocevar
