[OpenLayers-Users] Scalebar not visible
sendeman martijnsendenspam at gmail.com
Sat Jun 20 06:01:59 EDT 2009
Hi, Thanks for your reply. I continued this thread in
http://n2.nabble.com/WFS-layer-visible-in-IE6-and-IE7%2C-but-not-in-Firefox.-Tried-to-set-up-proxy.-No-succes-yet.-td3113693.html
another thread , for which you also gave me an answer.
Best regards,
Martijn Senden.
Andreas Hocevar-2 wrote:
> Hi,
> usually when you do not get a reply to a question within a day, then
> there is probably information missing that would allow for quick
> examination of the problem. So just re-posting the same question may
> not be the best way to get a reply.
> In this specific case, we know that you are using the hosted version
> of the OpenLayers API, but we have no idea what hides behind your
> openlayers_scalebar.js and css/scalebar.css.
> Anyway, a quick glance at your code shows me that the units property
> of the map should not be "meters", but "m". Maybe changing this will
> get you somewhere.
> Also, if you use a single file build of OpenLayers, you should also
> add the theme/default/style.css stylesheet to your webpage.
> Regards,
> Andreas.
> On Fri, Jun 19, 2009 at 11:07 AM, sendeman<martijnsendenspam at gmail.com>
> wrote:
>> Hi again,
>> I'm still struggling with the scalebar problem I described earlier (see
>> below). Does anyone see an error in the code I posted? Do I need to
>> provide
>> additional information? Please let me know if I need to give more input.
>> Thanks again in advance!
>> Best regards,
>> Martijn Senden.
>> sendeman wrote:
>>> Hi All,
>>> Does anyone have a solution for the problem I described earlier (see
>>> below)? I haven't been able to tackle it yet. Thanks a lot in advance!
>>> Best regards,
>>> Martijn Senden.
>>> sendeman wrote:
>>>> Hi all!
>>>> I'm trying to add a scalebar to my mapserver + openlayers webapp. I
>>>> tried
>>>> implementing
>>>> http://dev.openlayers.org/addins/scalebar/trunk/examples/scalebar.html
>>>> the online example  into my own page, but until now, I haven't
>>>> succeeded.
>>>> I used firebug to see the generated source and the javascript does add
>>>> divs for the scalebar, I just don't see it anywhere. I have made no
>>>> changes to the css or javascript, just changed the location and
>>>> filename.
>>>> The src values of the scripts and href of the linked stylesheet are
>>>> correct.
>>>> I added the code I used below.
>>>> Does anyone see what's going wrong? Because I don't. :-)
>>>> Thanks in advance, any help will be greatly appreciated!
>>>> Best regards,
>>>> Martijn Senden.
>>>> _________________________________________________________________
>>>> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN"
>>>> "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
>>>> <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en"
>>>> lang="en"><head>
>>>> <title>Untitled</title>
>>>> <style type="text/css">
>>>> body,
>>>> html {
>>>>      overflow: hidden;
>>>>      height: 100%;
>>>> #map {
>>>>      position: absolute;
>>>>      z-index:1;
>>>>      top: 100px;
>>>>      bottom: 50px;
>>>>      left: 0;
>>>>      width: 70%;
>>>>      /* height:80%; */
>>>>      border: 1px solid black;
>>>>      background: red;
>>>> #scalebar {
>>>>   position: absolute;
>>>>   right: 0;
>>>>   bottom: 50px;
>>>>   width: 25%;
>>>>   height: 200px;
>>>>   border: 1px solid #000;
>>>> </style>
>>>> <!--[if lte IE 8]>
>>>> #map {
>>>>      bottom: auto;
>>>>      height: expression(document.documentElement.clientHeight - 150
>>>> +"px");
>>>> </style>
>>>> <![endif]-->
>>>> <script type="text/javascript"
>>>> src="http://openlayers.org/api/OpenLayers.js"></script>
>>>> src="javascript/openlayers_scalebar.js"></script>
>>>> <link href="css/scalebar.css" rel="stylesheet" type="text/css"
>>>> media="screen">
>>>> <script type="text/javascript">
>>>> function init(){
>>>>   //Create a new OpenLayers mapwindow with associated controls
>>>>   var map = new OpenLayers.Map('map', {
>>>>              projection: "EPSG:28992",
>>>>              maxResolution: 1328.125,
>>>>              numZoomLevels: 14,
>>>>              maxExtent : new
>>>> OpenLayers.Bounds(-23500,289000,316500,629000),
>>>>              restrictedExtent: new
>>>> OpenLayers.Bounds(80000,442000,88000,452000),
>>>>              units : "meters",
>>>>              controls: [
>>>>                      new OpenLayers.Control.ZoomToMaxExtent(),
>>>>                      new OpenLayers.Control.PanZoomBar({zoomWorldIcon:
>>>> true}),
>>>>                      new
>>>> OpenLayers.Control.LayerSwitcher({'ascending':false}),
>>>>                      new OpenLayers.Control.MouseDefaults(),
>>>>                      new OpenLayers.Control.KeyboardDefaults()
>>>>   // Add Spoortunnel Delft Mapserver .map-files
>>>>   layer = new OpenLayers.Layer.MapServer( "Topografie",
>>>>           "/geoviewerbin/mapserv.exe", {map:
>>>> "c:/OSGeo4W/apps/geoviewer/maps/spoortunnel.map", layers: "Topografie"}
>>>>   map.addLayer(layer);
>>>>   //Add a scalebar to the map
>>>>   scalebar = new OpenLayers.Control.ScaleBar();
>>>>   map.addControl(scalebar);
>>>>   map.zoomToExtent(new OpenLayers.Bounds(83600,446000,84600,448200));
>>>> window.onload=init;
>>>> </script>
>>>> </head><body>
>>>> <div id="map"></div>
>>>> </body></html>
>> View this message in context:
>> http://n2.nabble.com/Scalebar-not-visible-tp3086564p3118597.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
View this message in context: http://n2.nabble.com/Scalebar-not-visible-tp3086564p3124239.html
