[OpenLayers-Users] Overlay on Google
toni hernández
tonidelacalle at gmail.com
Mon Jun 22 09:15:00 EDT 2009
You should configure ArcGIS to serve 900913. I do not even know if that is
possible. I guess it is.
OpenLayers can't reproject itself.
On Mon, Jun 22, 2009 at 2:26 PM, moony <k_karo at web.de> wrote:
> Hi all,
> I want to use Google Maps as baselayer and overlay wms, which are delivered
> by ArcGIS Server.
> OpenLayers is always using "epsg:900913", but ArcGIS Servers uses "epsg:
> 102113" for the google projection.
> How can I force OpenLayers to use "epsg: 102113" instead of "epsg: 900913"?
> Defining the projection in the options doesn't work.
> var options = {
> projection: new OpenLayers.Projection("EPSG:102113"),
> //projection: new OpenLayers.Projection("EPSG:900913"),
> //displayProjection: new OpenLayers.Projection("EPSG:4326"),
> units: "m",
> numZoomLevels: 18,
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
> 20037508, 20037508.34)
> map = new OpenLayers.Map('map', options);
> var gphy = new OpenLayers.Layer.Google(
> "Google Physical",
> {type: G_HYBRID_MAP, 'sphericalMercator': true}
> var wms = new OpenLayers.Layer.WMS( "Fläche natürlicher Vegetation pro
> Einwohner",
> http://xen1ags:8399/arcgis/services/Monitor/Bevoelkerung_Web/MapServer/WMSServer
> {layers: '0', srs: 'EPSG:102113',format:
> 'image/png', transparent:
> 'true'},
> {singleTile: true, isBaseLayer: false}
> map.addLayers([gphy,wms]);
> http://n2.nabble.com/Overlay-on-Google-tp2973539p3135908.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090622/d187687d/attachment.html
