[OpenLayers-Users] WFS format problem
Balázs Bámer bamerbalazs at gmail.com
Tue Jun 23 15:47:55 EDT 2009
Hi All,
I'm sorry, the URL is missing:
http://att-it.homelinux.net:22080/blokknezegeto/
2009/6/23 Balázs Bámer <bamerbalazs at gmail.com>:
> Hi All,
> I'm trying to write a small example with WFS attribute search. I use
> OpenLayers 2.8 (non-minified), I've tried under Firefox 3.0.6 with
> Firebug 1.3.3 The problem is in file OpenLayers/Protocol/WFS/v1.js in
> lines 154-156:
> 154 var data = OpenLayers.Format.XML.prototype.write.apply(
> 155 this.format, [this.format.writeNode("wfs:GetFeature", options)]
> 156 );
> in this stack frame, this.format is of type OpenLayers.Format.GML as
> I've created it. As I enter function writeNode in line 155, I find
> myself in
> 678 writeNode: function(name, obj, parent) {
> 679 var prefix, local;
> 680 var split = name.indexOf(":");
> 681 if(split > 0) {
> 682 prefix = name.substring(0, split);
> which is in file OpenLayers.Format.XML.js instead of GML. Here, in line
> 692 var child = this.writers[prefix][local].apply(this, [obj]);
> the execution stops because this.writers[prefix] is undefined.
> To use the example, copy D5WRJ105 in the lower form and hit the Keres button.
> What is the problem?
> thank you in advance, best regards: Balázs
