[OpenLayers-Users] IE problems with OL + dojo
William Kyngesburye
woklist at kyngchaos.com
Thu Mar 26 17:16:26 EDT 2009
I mostly have OL working with the Dojo js library. The main key I
found was to load OL *after* dojo, or neither would work right.
The map displays correctly, and the dojo layout stuff works, in Safari
and Firefox, but IE6+ has problems.
With a tiled base layer, one or more of the tiles is not rendering in
the initial view (max extents), and the bigger the window, the more
missing. If I zoom in, then back out to the max extents, it renders
all tiles.
Also, when exiting the web page, there is a javascript error. The
best I could debug it, with companion.js, there is an invalid argument
error in Map.js line 890 (multi-file OL), or a syntax error on line
891, depending on whether the map page is embedded in another page or
not. (OL 2.7).
The same OL map using mapfish/ext does not have these problems.
I wonder if Dojo is redefining something that OL needs, that only
affects IE browsers? Or Dojo is changing the DOM differently in IE,
and in a way OL doesn't like? My debugging capability is limited on
the IE side. And this whole adventure (first mapfish, then dojo) has
been a crash course in javascript, so I'm still learning ;)
If anyone cares to look, the non-embedded version:
http://www.mappingspecialists.com/maps/windex-full-dev-dojo.php
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do if
you ARE a maniacally depressed robot? No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
