[OpenLayers-Users] Problems adding polygon data from GML
David Alda Fernandez de Lezea dalda at ikt.es
Wed Nov 4 03:44:12 EST 2009
Thanks, at least I have a refutated information. Now I know it, and the next time I hope not to make the same mistake, but I still don't understand why two weeks ago worked, and yesterday it didn't. Anyway, from now on I'll follow the specifications more accuratelly. Thanks.
Un saludo,
David Alda Fernández de Lezea
Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
IKT
Granja Modelo s/n · 01192 · Arkaute (Araba)
Tlfnos.: 945-00-32-95                         Fax: 945-00.32.90
email: dalda at ikt.es                                web: www.ikt.es
-----Mensaje original-----
De: Roald de Wit [mailto:roald.dewit at lisasoft.com]
Enviado el: miércoles, 04 de noviembre de 2009 9:32
Para: David Alda Fernandez de Lezea
CC: users at openlayers.org
Asunto: Re: [OpenLayers-Users] Problems adding polygon data from GML
Hi David,
David Alda Fernandez de Lezea wrote:
> Is there anything here that makes you know that the response of the WFS Service is in GML v3?
> How can you specify it in the map file?
> The getFeature request I use is this:
> http://192.168.1.65/cgi-bin/mapserv.exe?map=../htdocs/MFD/ejemplo_wfs.
> map&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&MAXFEATURES=1000&EXCE
> PTIONS=application/vnd.ogc.se_xml&TYPENAME=RecintosSigpac&FILTER=<Filt
> er><PropertyIsEqualTo><PropertyName>GID</PropertyName><Literal>125</Li
> teral></PropertyIsEqualTo></Filter>
Your WFS request has version 1.1.0. That implies that you receive GML v3 output. See this document: [1] for some differences between 1.0 and 1.1.
If you were to specify your request to be 1.0, you would get GML v2 back!
[1] https://www.e-education.psu.edu/geog585/l3_p9.html
Regards, Roald
