[OpenLayers-Users] Highlighting changes in the KML layer
Adrian Popa
adrian_gh.popa at romtelecom.ro
Thu Nov 5 01:52:22 EST 2009
Thanks Roald,
I will read on and give it a go. I will post my solution when it's ready
(I estimate in about ~1month).
Regards,
Adrian
Roald de Wit wrote:
> Hi Adrian,
> When you refresh a layer (someone please correct me if I'm wrong
> here), all your features (items) will be replaced with the new ones,
> therefore you need to 'manually' keep track of your features. As you
> suggested, you could, just before a refresh, store all features (or
> feature.ids) in some array, then refresh and compare the new feature
> list with the old one.
> The refresh is usually not synchronous, but that does not need to be a
> problem: you can register for events ('beforefeaturesadded' for
> example) and call your compare function with the list of new features.
> You can then loop through them and mark the new ones as new (for
> example by saying: feature.attributes.isNew = true). Make sure that
> the compare function itself returns true.
> Have a look at what's possible with styling in OpenLayes (it's a bit
> of a read): http://docs.openlayers.org/library/feature_styling.html
> So, yes, your plan sounds good!
> Regards, Roald
> Adrian Popa wrote:
>> Hello Roald,
>> I have a question about marking items as new - I guess they are not
>> marked out of the box, right?
>> When I do the layer refresh, I just do layer.refresh({force: true});
>> I'm not sure what this does internally, but perhaps I can't count on
>> any attributes I set - to be preserved.
>> Should I build the variable (hash) where I keep attributes as a
>> different variable? Or should I keep it in a standalone object?
>> Also, before I do the refresh - I suspect I need to copy the
>> attributes of the current objects, issue a layer refresh and then
>> (hoping the refresh is synchroneous) I should go through the new list
>> and see if I have new items. If there are, mark them as new (and mark
>> other items as 'old').
>> Supposing that I do that - what would I need to do to change the
>> aspect (change color/make bigger) of the "new" items?
>> I'm afraid this will consume some memory and resources - but I guess
>> I will see when it's ready...
>> How does my plan sound like?
>> Regards,
>> Adrian
>> Roald de Wit wrote:
>>> Hi Adrian,
>>> Adrian Popa wrote:
>>>> Thank you for the hint. I suppose I shouldn't expect to see a
>>>> working demo of what I need :)
>>>> Do you know if the patches presented in ticket 1259 are already
>>>> part of openlayers (since the latest version is from january last
>>>> year?)
>>> The patches in that ticket are part of OpenLayers since version 2.6,
>>> so, yes!
>>> I'm not sure if you use styling coming from the KML file or style it
>>> all yourself. In your case I think you need to revert to the latter
>>> case. You will need to do some magic to find out what features are
>>> new and apply a different style to those items. There are few
>>> different ways of doing it. One of them might be marking it's
>>> 'newness' in an attribute of the new feature(s) and use a rule that
>>> checks that attribute in your style map.
>>> Regards,
>>> Roald
>>>> Thanks,
>>>> helmi wrote:
>>>>> The idea from http://trac.openlayers.org/ticket/1259
>>>>> You could create a selectStyle that could be passed to
>>>>> Control.SelectFeature quite easily: create a style object, read
>>>>> the "highlight" styles, create a FidFilter rule for every feature
>>>>> (or groups of features with the same style), use the according
>>>>> "highlight" style as symbolizer for the rule, and add the rule to
>>>>> the style object
>>>>> helmi03.com <http://helmi03.com>
>>>>> On Tue, Nov 3, 2009 at 12:59 AM, Adrian Popa
>>>>> <adrian_gh.popa at romtelecom.ro
>>>>> <mailto:adrian_gh.popa at romtelecom.ro>> wrote:
>>>>> Hello everyone,
>>>>> Sorry if this has already been discussed on the list (didn't
>>>>> really
>>>>> check), but I would like to know if there is a solution (or at
>>>>> least a
>>>>> plan to implement a feature) that �"somehow" highlights
>>>>> (visually) the
>>>>> elements that have been loaded �through KML - in contrast to the
>>>>> elements displayed previously.
>>>>> I am working at a view that displays alarms on top of the map,
>>>>> and if
>>>>> there is a large number of alarms, one more alarm coming every 2
>>>>> minutes
>>>>> will not catch the attention of the operator...
>>>>> I need a mechanism to somehow color/animate symbols loaded
>>>>> through KML
>>>>> which were not previously on the map. Symbols which dissapear
>>>>> between
>>>>> layer refreshes are not important to me. At the next refresh
>>>>> cycle, the
>>>>> highlighted symbols would no longer be highlighted (because they
>>>>> already
>>>>> exist on the map).
>>>>> I have a way to load KMLs periodically, avoiding the cache,
>>>>> but I'm
>>>>> missing the "highlight" mechanism.
>>>>> Hope I have presented my request in an understandable manner, and
>>>>> hope
>>>>> there is a solution. Maybe a property on the KML layer indicating
>>>>> if an
>>>>> item is new or not...
>>>>> Regards,
>>>>> Adrian
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at openlayers.org <mailto:Users at openlayers.org>
>>>>> http://openlayers.org/mailman/listinfo/users
