[OpenLayers-Users] transform help please
Richard Marsden
winwaed at gmail.com
Thu Nov 19 14:01:58 EST 2009
It looks like you are trying to re-project Google raster layers?
I thought OpenLayers was only capable of re-projecting vector layers?
For example, the following article uses OpenLayers (& Proj4JS) to re-project
KML and GeoRSS data (geographic coords, WGS84) to a number of different
projections (Mollweide, Behrmann, etc):
http://www.geowebguru.com/articles/209-how-to-create-an-online-map-with-a-non-mercator-projection-part-2
Richard Marsden
Winwaed Software Technology LLC
http://www.winwaed.com
http://www.mapping-tools.com
http://www.geowebguruc.om
On Thu, Nov 19, 2009 at 12:12 PM, Dash <jimlug at co.clackamas.or.us> wrote:
> Aloha Thursday folks,
> I am banging my head against the problem for the last several hours. I
> have
> went through numerous examples and utilized OpenLayers tutorial on
> reprojecting points without any success. I've even used the Proj4js Wiki
> without any help. Could some please shed some light on what I am doing
> wrong?
> Here is the scenario. I am trying to transform some coordinates from
> EPSG:2913 to EPSG:900913. I've also tried a simplified version using
> EPSG:4326 -> EPSG:900913. Anyway, the transform is not happening for some
> odd reason. I do have the proj4js library within my code and I have added
> EPSG definition to my /proj4js/lib/def directory. I am checking if the
> projection by using the getUnits function of the projection class within
> OpenLayers. If the units come back null, then the proj4js library is
> unavailable. Why is this? I'm so confused. This should be rather
> straight
> forward. Anyway, here is some of my code. Hopefully someone can help me
> out. Thanks.
> <head>
> <script src="http://openlayers.org/dev/lib/OpenLayers.js"
> type="text/javascript"></script>
> <script src="./proj4js/lib/proj4js.js"></script>
> <script src="proj4js/lib/defs/EPSG2913.js"></script>
> <script src="proj4js/lib/defs/EPSG900913.js"></script>
> <script src="proj4js/lib/defs/EPSG4326.js"></script>
> </head>
> <script type="text/javascript">
> var map;
> function init(){
> var options = {
> //projection: new OpenLayers.Projection("EPSG:900913"),
> // Map projection
> projection: "EPSG:900913",
> displayProjection: new OpenLayers.Projection("EPSG:4326"),
> // Display
> projection
> units: "m",
> numZoomLevels: 5,
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(-13698618.8209569, 5595988.4768255,
> -13521569.8682338, 5701506.49106001)
> // Initiate Map Controls
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.addControl(new OpenLayers.Control.MousePosition());
> // Create Google Mercator Layers
> var gmap = new OpenLayers.Layer.Google("Google
> Streets",{'sphericalMercator': true, numZoomLevels: 20});
> var gphy = new OpenLayers.Layer.Google("Google Physical",
> {'sphericalMercator': true, type: G_PHYSICAL_MAP, numZoomLevels: 20});
> var gsat = new OpenLayers.Layer.Google("Google
> Satellite",{'sphericalMercator': true, type: G_SATELLITE_MAP,
> numZoomLevels:
> 20});
> var ghyb = new OpenLayers.Layer.Google("Google
> Hybrid",{'sphericalMercator': true, type: G_HYBRID_MAP, numZoomLevels:
> 20});
> map.addLayers([gmap, gphy, gsat, ghyb]);
> var srcProj = new OpenLayers.Projection("EPSG:4326");
> alert(srcProj.getUnits());
> var point = new OpenLayers.LonLat(-71, 42);
> point.transform(srcProj, map.getProjectionObject());
> if(point.transformed)
> alert("point already transformed");
> Proj4js.transform(srcProj, map.getProjectionObject(), point);
> Any suggestions would be greatly appreciated. THANKS...
> http://n2.nabble.com/transform-help-please-tp4033462p4033462.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091119/bbdfc5a4/attachment.html
