[OpenLayers-Users] Vector disappears when zooming in (sometimes)
Andreas Hocevar
ahocevar at opengeo.org
Sat Nov 21 04:33:25 EST 2009
Hey-
things like this can happen when the renderer (VML in your case) runs
out of coordinate space. If you can serve your vector data through
something that supports a BBOX filter (i.e. e.g. a WFS or FeatureServer,
but not a static file), you can use a BBOX strategy on your vector layer
to avoid the issue.
Regards,
Andreas.
Tommy74 wrote:
> Hi
> I'm trying to draw a long linestring on a map. On IE7 the line disappears on
> the southern end when zooming in max. But on the northern end the line is
> still there. Is it a bug or have I done something wrong?
> http://n2.nabble.com/file/n4040736/Tutorial2.html Tutorial2.html
> http://n2.nabble.com/file/n4040736/Route.js Route.js
> Since I have an internal WMS the background will not be visible for you but
> you should be able to see the linestring that is read from Route.js-file.
> Thanks in advance
> /Tommy
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
