[OpenLayers-Users] WFS-T
Alexandre Dube adube at mapgears.com
Wed Nov 25 10:59:41 EST 2009
Hey,
40.000 is sure big.  You could try the Cluster strategy [1], or have you
points in WMS when zoomed out then changed to WFS when zoomed in.  The
latter is what I'm doing in the demo I sent you.  Load it, then zoom
out.  You'll see that the roads switch from WFS to WMS.  You could also
do that.
Best regards,
Alexandre
[1] http://openlayers.org/dev/examples/strategy-cluster.html
JuKiM wrote:
> Ok..
> And about the other question.. If in the datasource there are about
> 40.000 positions... Is a good way to try loading them with WFS? Or
> using WMS is recommended?
> Thanks!
> 2009/11/25 Alexandre Dube <adube at mapgears.com <mailto:adube at mapgears.com>>
>     Hi,
>      Just before your commit, you need to copy the your field values
>     to the feature's attributes.  They will then be part of the
>     'insert' request sent to your server.  See an example (demo) of
>     what I'm talking about [1].  It uses TinyOWS, but it should be
>     similar to what you're seeking to do.
>      Hope this helps,
>     Alexandre
>     [1] http://dev4.mapgears.com/bdga/bdgaWFS-T.html
>     JuKiM wrote:
>         Hi,
>         I'm searching documentation about WFS-T, because with I can
>         understand, it let to create new entries in the datastore
>         through the GeoServer....
>         I create the map, and a wms layers which is displayed, and
>         then I create the wfs layer..
>         wfs = new
>         OpenLayers.Layer.WFS("Test_Layer","http://localhost:8080/geoserver/wfs",
>                        {typename: 'Test:dots'},
>                            typename: "dots",
>                            featureNS: "http://www.uriURL.org/test",
>                            extractAttributes: false,
>                            commitReport: function(str) {
>                             alert(str);
>                                OpenLayers.Console.log(str);
>         var draw = new OpenLayers.Control.DrawFeature(
>                        wfs, OpenLayers.Handler.Point,
>                            handlerOptions: {freehand: false, multi: true},
>                            displayClass: "olControlDrawFeaturePoint"
>                                var save = new OpenLayers.Control.Button({
>                        trigger: OpenLayers.Function.bind(wfs.commit, wfs),
>                        displayClass: "olControlSaveFeatures"
>                              panel.addControls([
>                        new OpenLayers.Control.Navigation(),
>                        save, draw
>                      map.addControl(panel);
>         When I save the new points, they are insterted in the DB, but
>         with empty values.. Only the auto incremental id is created..
>         In my table there are four fields, 'id', 'location',
>         'description', 'type'. How can I configure the WFS calls to
>         create the new entries with all the information? (The
>         information about description and type is the same, and is
>         stored in a textfield, and the location should be the
>         different points of the map..
>         And on the other hand, if the datasource contains about 40.000
>         positions, is better to work with WMS and process the
>         information in server side?
>         Thanks!
>         _______________________________________________
>         Users mailing list
>         Users at openlayers.org <mailto:Users at openlayers.org>
>         http://openlayers.org/mailman/listinfo/users
>     Alexandre Dubé
>     Mapgears
>     www.mapgears.com <http://www.mapgears.com>
Alexandre Dubé
Mapgears
www.mapgears.com
