[OpenLayers-Users] problem with WFS GetFeature
    Andreas Hocevar
    ahocevar at opengeo.org
    Wed Nov 25 14:06:18 EST 2009
Try to do the following:
protocol: OpenLayers.Protocol.WFS.fromWMSLayer(layer, {
    featureNS: "http://mapserver.gis.umn.edu/mapserver",
    featurePrefix: "ms",
    geometryName: "msGeometry"
Note that this looks more like WFS1.0.0 with GML2, so if the above still
does not work, add
    version: "1.0.0"
Regards,
Andreas.
pablo lopez wrote:
> Ok, here's the XML response from the server:
> ?xml version='1.0' encoding="ISO-8859-1" ?>
> <wfs:FeatureCollection
>    xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
>    xmlns:gml="http://www.opengis.net/gml"
>    xmlns:wfs="http://www.opengis.net/wfs"
>    xmlns:ogc="http://www.opengis.net/ogc"
>    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>    xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
> http://localhost/cgi-bin/mapserv?map=/var/www/aplicaciones/sined/regsanu.map&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=regs_anu&OUTPUTFORMAT=text/xml
> <http://localhost/cgi-bin/mapserv?map=/var/www/aplicaciones/sined/regsanu.map&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=regs_anu&OUTPUTFORMAT=text/xml>;
> subtype=gml/3.1.1  http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
>       <gml:boundedBy>
>           <gml:Envelope srsName="EPSG:4326">
>               <gml:lowerCorner>-107.210132 21.041869</gml:lowerCorner>
>               <gml:upperCorner>-97.144224 29.880024</gml:upperCorner>
>           </gml:Envelope>
>       </gml:boundedBy>
>     <gml:featureMember>
>       <ms:regs_anu gml:id="regs_anu.1">
>         <gml:boundedBy>
>             </gml:Envelope>
>         </gml:boundedBy>
>         <ms:msGeometry>?xml version='1.0' encoding="ISO-8859-1" ?>
>       <gml:boundedBy>
>           </gml:Envelope>
>       </gml:boundedBy>
>     <gml:featureMember>
>         <gml:boundedBy>
>             </gml:Envelope>
>         </gml:boundedBy>
>         <ms:msGeometry>
>           <gml:Polygon srsName="EPSG:4326">
>             <gml:exterior>
>               <gml:LinearRing>.....some coordinates
> Thanks in advance
> Pablo
> On Wed, Nov 25, 2009 at 12:20 PM, Andreas Hocevar
> <ahocevar at opengeo.org <mailto:ahocevar at opengeo.org>> wrote:
>     pablo lopez wrote:
>         Thanks Andreas, I've just tried your suggestion and it didn't
>         work. I'm now taking a look at the gml returned by mapserver
>         to see if I need to specify more parameters.
>         On the other hand, I was looking at the highlight feature code
>         in http://trac.openlayers.org/wiki/Highlighting, and I wonder
>         if there is a way to control the highlighting with mouse
>         clicks instead of filters.
>         Any suggestions on this?
>     This is only recommended if you have very few features. The
>     prerequisite is to load the layer as vector layer, not from WMS.
>     But back to the original problem. If you provide a sample XML that
>     your server returns, it will be easier to see what is wrong.
>     Regards,
>     Andreas.
>         Regards,
>         Pablo
>         On Wed, Nov 25, 2009 at 1:31 AM, Andreas Hocevar
>         <mailto:ahocevar at opengeo.org <mailto:ahocevar at opengeo.org>>>
>         wrote:
>            Hi,
>            can you please try the following and report back if it works:
>            pablo lopez wrote:
>                           control = new OpenLayers.Control.GetFeature({
>                               protocol:
>                OpenLayers.Protocol.WFS.fromWMSLayer(layer),
>            Instead, use
>                          protocol:
>                              featurePrefix: "feature"
>            That's the only idea I have.
>            Regards,
>            Andreas.
>            --    Andreas Hocevar
>            OpenGeo - http://opengeo.org/
>            Expert service straight from the developers.
>         _______________________________________________
>         Users mailing list
>         Users at openlayers.org <mailto:Users at openlayers.org>
>         http://openlayers.org/mailman/listinfo/users
>     Andreas Hocevar
> Users mailing list
Andreas Hocevar
