[OpenLayers-Users] WFS + Text (Text_Symbolizer)
stash steffen.schwarz85 at googlemail.com
Fri Nov 27 03:27:13 EST 2009
Ivan Grcic-2 wrote:
> http://openlayers.org/dev/examples/vector-features-with-text.html
thanks for the example. After studying it, I copied the code, changed it for
my app and it worked.
But the disadvantage in the example is, that a predefined text (in my app i
used: "test") is used by the stylemap.
Because I don't want to have the same text at each point I have a small
problem.
The text for each point is stored in my database (which is connected to a
layer in geoserver). Now I want to use the text from the database for each
point instead of predefining some text.
Is this possible? Can you tell me how to implement this.
Thanks for the help.
Regards
stash
View this message in context: http://n2.nabble.com/WFS-Text-Text-Symbolizer-tp4071914p4074588.html
