[OpenLayers-Users] IE: OpenLayers not visible
Andreas Hocevar ahocevar at opengeo.org
Sun Nov 29 11:43:39 EST 2009
Chau wrote:
> That is so true, but in those cases - for me atleast - IE responds with an
> error pointing at some random object error.
> I my case, it was a question of trying to create a fullscreen map, which
> resulted in my map being invisible in IE, but still available for
> manipulation. How I am able to move around in an invisible map, I don't
> know.
Fullscreen? This is a CSS issue. If you want that to work, you have to
either make your page run in quirks mode (i.e. without setting a
doctype, see http://openlayers.org/dev/examples/fullScreen.html), or you
need to set a width and height of 100% not just on your map div, but
also on the body and the html elements of your document
Regards,
Andreas.
Regards,
Andreas.
> Kenneth, Thanks for your fast answer.
> /Casper
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
