[OpenLayers-Users] Result of expression 'map' [undefined] is not an object.
P Kishor punk.kish at gmail.com
Sun Oct 4 23:53:18 EDT 2009
On Sun, Oct 4, 2009 at 10:44 PM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Kishor,
> I'm pretty sure that the trailing common is not portable across browsers, as
> I'm sure I have had problems with that in the past. It is a common model
> that I learned in Perl, but it is not supported by most other languages. :(
Yup, I too picked up that good habit in Perl, and thoroughly enjoy
being lazy with it. That said, I am doing development right now and
testing in both Safari 4.x and Firefox 3.5x, and the trailing comma
seems to work fine. I don't have access to any version of IE (well,
not easily anyway) so I haven't really tested.
Can someone please confirm the browsers/versions in which the trailing
comma croaks?
> -Steve
> P Kishor wrote:
>> On Sun, Oct 4, 2009 at 12:13 PM, Andreas Hocevar <ahocevar at opengeo.org>
>> wrote:
>>> Also make sure that you don't have extra commas at the end of object
>>> definitions.
>> if you mean, do like this
>> var foo = { a: 'blah', b: 'blech' };
>> and not like
>> var foo = { a: 'blah', b: 'blech', };
>> let me ask you, why not? Javascript doesn't mind, and it makes my
>> programming a lot easier to let there be a comma at the end.
>>> Regards,
>>> Andreas.
>>> Stephen Woodbridge wrote:
>>>> Nicholas Efremov-Kendall wrote:
>>>>> Hi all,
>>>>> I'm getting the following error in what used to be functional
>>>>> code Result of expression 'map' [undefined] is not an object.
>>>>> It's breaking on the statement map.addLayer(cities). Here's the
>>>>> exerpted
>>>>> code that I've added around this. I can add a stripped down version of
>>>>> the rest, but it's bulky and I've only messed with the following bits.
>>>>> Any suggestions as to what's causing this error?
>>>>> var styleMap = new OpenLayers.StyleMap(
>>>>> {'default':OpenLayers.Util.applyDefaults(
>>>>>      label: '${Name}',
>>>>>      strokeWidth:1,
>>>>>      strokeColor:"#CCCCCC",
>>>>>      fillColor: "green",
>>>>> var cities = new OpenLayers.Layer.GML
>>>>> ("7th Century Cities", "data/cities.gml",
>>>>> styleMap: styleMap,
>>>>> projection: new OpenLayers.Projection("EPSG:4326"),
>>>>> format: OpenLayers.Format.GML,
>>>>> label: "${Name}",
>>>>> map.addLayer(cities);
>>>> Where is "var map" defined. It sounds like it is not in the visible
>>>> scope of the above code.
>>>> -Steve W
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Andreas Hocevar
>>> OpenGeo - http://opengeo.org/
>>> Expert service straight from the developers.
>>> Users mailing list
Puneet Kishor http://www.punkish.org
Carbon Model http://carbonmodel.org
Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
Nelson Institute, UW-Madison http://www.nelson.wisc.edu
Assertions are politics; backing up assertions with evidence is science
Sent from Madison, WI, United States
