[OpenLayers-Users] Looking for a progress bar or loading...
(image) that works in both IE and Firefox - while loading the map
Michael Shishcu
micklesh at gmail.com
Mon Oct 5 14:23:49 EDT 2009
Hi, Jim
I have tested the LoadingPanel.js i IE 6, 7, 8, and it works great.
Are there some errors in your script?
Check the order in which you are adding LoadingPanel.js (this needs to be
added AFTER Opnlayers.js, at least in IE6,7)
regards, michael
2009/10/5 <jim.meyer at concept-solutions.com>
> Hello,
> I am searching for a progress bar or loading image that will work
> effectively in IE and Firefox. I’d like the solution to display over the
> map DIV while the layers are being loaded and rendered. I have tried the
> LoadingPanel.js (http://trac.openlayers.org/wiki/Addins/LoadingPanel)
> solution and it works well in Firefox but it doesn’t seem to do the trick in
> IE. Any help would be appreciated.
> Thanks,
> Jim
> Jim Meyer
> Java Programmer
> *Concept**Solutions*, LLC
> We Make Business Intelligent
> 703.889.8434 [desk]
> 703.391.9041[fax]
> www.*Concept-**Solutions*.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091005/43b9f267/attachment.html
