[OpenLayers-Users] Popup Attribute Display format
Marc Jansen
jansen at terrestris.de
Sat Oct 10 07:51:51 EDT 2009
Hi Cress,
Play around with the INFO_FORMAT-parameter of the
getFeatureInfo-Request. E.g. "application/vnd.ogc.gml" would perhaps be
better suited.
INFO_FORMAT: 'application/vnd.ogc.gml',
Afterwards look at the response and try to parse/read the servers'
answer using a proper OpenLayers.Format. With the parsed info you can
build any HTML you want and insert it into the popup.
Regards,
Marc
Cress B. schrieb:
> Hi all,
> I'm now using a WMS mapfile to display tax lot polygons and want to have a
> popup display when the user clicks on the tax lot. I've successfully gotten
> the popup to work using the getfeatureinfo method. I can control which
> items appear in the popup with "wms_include_items" in the Metadata portion
> of the Layer in my mapfile. But I'm having trouble figuring out how to
> format the display of those items in the popup. Currently the popup has the
> attrubutes basically all run together as one long string. I would like to
> show each attribute name and value on a separate line within the popup.
> Any help would be GREATLY appreciated, including an example if possible.
> code snip:
> var createPopup = function(response) {
> var lonlat = map.getLonLatFromViewPortPx(this.xy);
> var popup = new OpenLayers.Popup.FramedCloud(
> "info",lonlat, null, response.responseText,null,true);
> popup.setBackgroundColor("#c1cdc1");
> popup.setOpacity(0.7);
> map.addPopup(popup, true /* exclusive */);
> function onFeatureUnselect(event) {
> var feature = event.feature;
> if(feature.popup) {
> map.removePopup(feature.popup);
> feature.popup.destroy();
> delete feature.popup;
> map.events.register('click', map, function (e) {
> var url = wms.getFullRequestString({
> REQUEST: "GetFeatureInfo",
> EXCEPTIONS: "application/vnd.ogc.se_xml",
> BBOX: wms.map.getExtent().toBBOX(),
> X: e.xy.x,
> Y: e.xy.y,
> INFO_FORMAT: 'text/plain',
> QUERY_LAYERS: 'taxlots',
> WIDTH: wms.map.size.w,
> HEIGHT: wms.map.size.h},
> "http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apache/htdocs/homeinfo_wms_v02.map&SERVICE=WMS&VERSION=1.1.1");
> OpenLayers.loadURL(url, '',e, createPopup);
> OpenLayers.Event.stop(e);
> Thanks,
> Cress
