[OpenLayers-Users] maxResolution for a WMS layer
Guillaume Sueur no-reply at neogeo-online.net
Tue Sep 1 04:28:16 EDT 2009
Eric Lemoine a écrit :
> On Monday, August 31, 2009, Guillaume Sueur <no-reply at neogeo-online.net> wrote:
>> Setting maxResolution after adding layer to the map did the trick.
> Setting maxResolution in the config object passed to the constructor
it does not
> should work. If it does not, I guess the problem should be reported.
I guess I should build a clean test case so.
> Hope you're well too.
I am !
Cheers,
Guillaume
