[OpenLayers-Users] Can OpenLayers APIs merge line features
Kevin Yang yangzhaozhao2008 at 163.com
Wed Sep 2 03:45:13 EDT 2009
Stephen Woodbridge wrote:
> Kevin Yang wrote:
>> Hello everyone,
>>     A problem troubled me for a long time. Can OpenLayers APIs merge line
>> features ?I use this function to solve the following problem: When I
>> calculate the shortest path, I get the WKTs of the LineStrings, but it is
>> not arranged  in sequence.So I cannot use the marker' MoveTo method to
>> implement the effct of a  little car picture going along the shortest
>> path
>> in sequence from start-node to end-node. Thus I want to consult you that
>> Can
>> OpenLayers APIs merge line  features ,and how to do it, or is there other
>> ways to solve this problem properly? Thank you very much!
>> best regards,
>> Yang
> I had a similar problem and was using pgRouting. The way I solved it was
> to have my Ajax server the gets the results from pgRouting do some
> additional checking and flip the segments so they are all in the same
> direction along the path. Basically, the segments are returned in the
> order of first to last, but because you might traverse a segment in the
> opposite direction than that which it is stored in the database you get
> the segment in reverse order. Your segments are all stored with A as the
> start and B as the end. Then you might get results back like:
> 1  2  3  4  5  6
> AB,AB,BA,AB,BA,BA,etc
> So you have to first see if the first segment needs to be flipped:
> if 1A == 2A or 1A == 2B then flip first segment,
> for i=2 through N {
>    if (i-1)B == iB then flip segment i
> now all the segments should be in the correct end to end order. and you
> can just chain them all together.
> I'm sure you can do the same in Javascript.
> -Steve W.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Thank you very much ,Steve W.!Best wishes for you!
View this message in context: http://n2.nabble.com/Can-OpenLayers-APIs-merge-line-features-tp3564159p3565265.html
