[OpenLayers-Users] keep map displayed when loading on zoom
Andreas Hocevar ahocevar at opengeo.org
Wed Sep 2 07:36:29 EDT 2009
Adrian Popa wrote:
> Sorry for butting in, but is this effect supposed to work also when
> the layer has singleTile='true'? (One image from mapserver)
Definitely. See the example.
Regards,
Andreas.
> Thanks
> Andreas Hocevar wrote:
>> Florent Gravin wrote:
>>> Is there a way to keep the map displayed when you zoom (with bad
>>> resolution) until the new tiles with a better resolution are loaded.
>>> Like for exemple in Google Map where you NEVER have white map because
>>> data are loading..
>> This can be done in OL too. All you need is to pass
>>     transitionEffect: "resize"
>> to the layer's options.
>> To see it in action and as a starting point for your own map, have a
>> look at http://www.openlayers.org/dev/examples/transition.html
>> Regards,
>> Andreas.
> Adrian Popa
> NOC Division
> Network Engineer
> Divizia Centrul National de Operare Retea
> Departament Transport IP & Metro
> Compartiment IP Core & Backbone
> Phone: +40 21 400 3099
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
