[OpenLayers-Users] keep map displayed when loading on zoom
Christopher Schmidt crschmidt at metacarta.com
Thu Sep 3 07:34:13 EDT 2009
On Thu, Sep 03, 2009 at 11:34:23AM +0300, Adrian Popa wrote:
> Thanks Andreas,
> I've tested it on Mapserver layers, and it works great!
> However, I  tried to add it to:
> - OpenStreetMaps (OpenLayers.Layer.OSM.Osmarender),
> - Google maps (OpenLayers.Layer.Google( 'Google Streets',
> {'sphericalMercator': true, transitionEffect: 'resize'} )
> - and yahoo maps (OpenLayers.Layer.Yahoo( 'Yahoo Street',
> {sphericalMercator:true, transitionEffect: 'resize'}))
> ... and it doesn't work for these ones.
> Is it supposed to work even for them?
No, these layers are controlled by the various commercial
APIs associated with them, and we do not have control over
the tile drawing. (It is possible these APIs have options to
control this behavior, but OpenLayers has no support for setting
those options.)
-- Chris
> Thanks
> Andreas Hocevar wrote:
>> Adrian Popa wrote:
>>> Sorry for butting in, but is this effect supposed to work also when
>>> the layer has singleTile='true'? (One image from mapserver)
>> Definitely. See the example.
>> Regards,
>> Andreas.
>>> Thanks
>>>> Florent Gravin wrote:
>>>>> Is there a way to keep the map displayed when you zoom (with bad
>>>>> resolution) until the new tiles with a better resolution are loaded.
>>>>> Like for exemple in Google Map where you NEVER have white map because
>>>>> data are loading..
>>>> This can be done in OL too. All you need is to pass
>>>>     transitionEffect: "resize"
>>>> to the layer's options.
>>>> To see it in action and as a starting point for your own map, have a
>>>> look at http://www.openlayers.org/dev/examples/transition.html
>>>> Regards,
>>>> Andreas.
>>> --- Adrian Popa
>>> NOC Division
>>> Network Engineer
>>> Divizia Centrul National de Operare Retea
>>> Departament Transport IP & Metro
>>> Compartiment IP Core & Backbone
>>> Phone: +40 21 400 3099
> --- Adrian Popa
> NOC Division
> Network Engineer
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
