[OpenLayers-Users] IE 7/8 Openlayers.js single File Problem
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Sep 3 10:19:44 EDT 2009
This is a known issue that was fixed in the 2.8 final:
http://trac.openlayers.org/ticket/1910
Perhaps it is a cache thing, or perhaps the OpenLayers.js you are
linking to is not the 2.8 final.
Regards, Kenneth Skovhede, GEOGRAF A/S
Max Weidemann skrev:
> Hello List,
> i have a problem with the single file Libary of Openlayers.
> (i use the version linked on the Homepage: "OpenLayers 2.8 -- $Revision:
> 9492 $")
> The Problem is the following:
> I try to show some different vectorlayer on a google map.
> Some Features of the vectorlayer have labels.
> If i use the multi file libary everything works fine, but if the single file
> libary is in use the IE8 throws an Error wich looks like this. >>> Invalid
> Argument (Openlayers.js line 597 character 110)<<<
> style.addRule('olv\\:*',"behavior: url(#default#VML); "+"position: absolute;
> display: inline-block;");
> The IE7 throws no Error but did not show the labels and in Firefox there are
> no Problems.
> I have tested if it works without labels but IE8 throws the same Error.
> I have absolutely no idea what the problem could be.
> Is there anything i could do to solve the problem???
> cheers
> Max
