[OpenLayers-Users] WMSGetFeatureInfo with IE
Micho Gar michogar at gmail.com
Thu Sep 3 12:04:04 EDT 2009
Can the problem is with the position of the map div?
I think that is.
2009/9/3 Micho Gar <michogar at gmail.com>
> Very strange.
> I have been investigating in the OpenLayers code and I have seen that the
> wms petition for the same point generate two diferent url. For FireFox
> respond with data and for IExplorer 7 not. The unique diference between both
> is the bbox. I dont understand anything.
> FF:
> http://192.168.11.159:8090/geoserver/wms?service=WMS&version=1.1.0&request=GetFeatureInfo&layers=osmius%3Ausuarios_instancias,osmius%3Ausuarios_servicios&query_layers=osmius%3Ausuarios_instancias,osmius%3Ausuarios_servicios&styles=,&bbox=-403214.87876%2C4928941.444487%2C-393278.065085%2C4934387.582751&srs=EPSG%3A900913&feature_count=10&x=520&y=283&height=570&width=1040&info_format=application%2Fvnd.ogc.gml&cql_filter=IDN_USER%3D'ROOT<http://192.168.11.159:8090/geoserver/wms?service=WMS&version=1.1.0&request=GetFeatureInfo&layers=osmius%3Ausuarios_instancias,osmius%3Ausuarios_servicios&query_layers=osmius%3Ausuarios_instancias,osmius%3Ausuarios_servicios&styles=,&bbox=-403214.87876%2C4928941.444487%2C-393278.065085%2C4934387.582751&srs=EPSG%3A900913&feature_count=10&x=520&y=283&height=570&width=1040&info_format=application%2Fvnd.ogc.gml&cql_filter=IDN_USER%3D%27ROOT>
> IE:
> http://192.168.11.159:8090/geoserver/wms?service=WMS&version=1.1.0&request=GetFeatureInfo&layers=osmius%3Ausuarios_instancias,osmius%3Ausuarios_servicios&query_layers=osmius%3Ausuarios_instancias,osmius%3Ausuarios_servicios&styles=,&bbox=-403195.769503%2C4928941.444487%2C-393297.174342%2C4934387.582751&srs=EPSG%3A900913&feature_count=10&x=504&y=283&height=570&width=1036&info_format=application%2Fvnd.ogc.gml&cql_filter=IDN_USER%3D'ROOT<http://192.168.11.159:8090/geoserver/wms?service=WMS&version=1.1.0&request=GetFeatureInfo&layers=osmius%3Ausuarios_instancias,osmius%3Ausuarios_servicios&query_layers=osmius%3Ausuarios_instancias,osmius%3Ausuarios_servicios&styles=,&bbox=-403195.769503%2C4928941.444487%2C-393297.174342%2C4934387.582751&srs=EPSG%3A900913&feature_count=10&x=504&y=283&height=570&width=1036&info_format=application%2Fvnd.ogc.gml&cql_filter=IDN_USER%3D%27ROOT>
> Here the control creation and activation in the init
>>     infoControls = {
>>             clickInstance: new OpenLayers.Control.WMSGetFeatureInfo({
>>                 url: context + '/geoserver/wms',
>>                 title: 'Identifica las features por click',
>>                 infoFormat: 'application/vnd.ogc.gml',
>>                 layers: [Instancias,Servicios],
>>                 queryVisible: true,
>>                 vendorParams:{ cql_filter: "IDN_USER='" + user + "'"}
>>     map.addLayers([Instancias,Servicios,MapnikLayer,OSMLayer]);
>>     infoControls['clickInstance'].events.register("getfeatureinfo", this,
>> getObject);
>>     map.addControl(infoControls['clickInstance']);
>>     infoControls['clickInstance'].activate();
>>     map.addControl(new OpenLayers.Control.Navigation());
>>     map.addControl(new OpenLayers.Control.PanPanel());
>>     map.addControl(new OpenLayers.Control.ZoomPanel());
>>     var layerSwitcher = new OpenLayers.Control.LayerSwitcher();
>>     layerSwitcher.activeColor='#E3F6CE';
>>     map.addControl(layerSwitcher);
>>     map.addControl(new OpenLayers.Control.Scale);
>>     map.addControl(new OpenLayers.Control.MousePosition);
>> and here the method is execute by control
>> function getObject(evt){
>>      g = new OpenLayers.Format.WMSGetFeatureInfo();
>>      var features = g.read(evt.text);
>>      if (features.length==0) return;
>>      if (features.length>1){
>>          if (repeats(features)==false){
>>              alert(msgOverObject);
>>              return;
>>      var idFeature=features[0].attributes['IDN_INSTANCE'];
>>      if (idFeature!=null){
>>         xyInfo = evt.xy;
>>         idObject=idFeature;
>>         var _url = context +
>> "/geoserver/wfs?VERSION=1.1.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=instancias_informacion&Filter=<Filter><PropertyIsEqualTo><PropertyName>IDN_INSTANCE</PropertyName><Literal>"
>> + idFeature + "</Literal></PropertyIsEqualTo></Filter>";
>>         OpenLayers.loadURL(_url, "", null, showInstanceInfo, isError);
>>      }else{
>>          var idService=features[0].attributes['IDN_SERVICE'];
>>          xyInfo= (new
>> OpenLayers.LonLat(features[0].geometry.x,features[0].geometry.y)).transform(proj4326,proj900913);
>>          idObject=idService;
>> "/geoserver/wfs?VERSION=1.1.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=usuarios_instancias&Filter=<Filter><And><PropertyIsEqualTo><PropertyName>IDN_SERVICE</PropertyName><Literal>"
>> + idService +
>> "</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>IDN_USER</PropertyName><Literal>"
>> + user + "</Literal></PropertyIsEqualTo></And></Filter>";
>>         OpenLayers.loadURL(_url, "", null, showServiceInstance, isError);
>> the evt param in the getObject method is empty in IE.
>> Thanks to all.
>> 2009/9/2 Eric Lemoine <eric.lemoine at camptocamp.com>
>> On Wed, Sep 2, 2009 at 7:13 PM, Micho Gar<michogar at gmail.com> wrote:
>>> > Hi all,
>>> > I have a code to realise a GetFeatureInfo and runs well on Firefox but
>>> not
>>> > return any result in IE. Reading the documentation I have not seen
>>> nothing
>>> > about this. I think it work the same for both.
>>> > Something about this??
>>> Some code to show the list?
>>> Eric Lemoine
>>> Camptocamp France SAS
>>> Savoie Technolac, BP 352
>>> 73377 Le Bourget du Lac, Cedex
>>> Tel : 00 33 4 79 44 44 96
>>> Mail : eric.lemoine at camptocamp.com
>>> http://www.camptocamp.com
>> # michogar
>> # Analista Programador SIG
>> # GNU/Linux Counter 462666
>> # http://www.openstreetmap.org/user/michogar
>> Una visión personal:
>> http://michogar.wordpress.com
>> El día a día:
>> http://twitter.com/michogar
> # michogar
> El día a día:
# michogar
El día a día:
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090903/9ce721e5/attachment.html
