[OpenLayers-Users] How Print openlayer Maps into pdf documents
fsalas fsalas at geocuba.cu
Thu Sep 3 14:22:28 EDT 2009
Thanks, Cheers
Francisco Salas
----- Original Message -----
To: "Alexandre Dube" <adube at mapgears.com>; "fsalas" <fsalas at geocuba.cu>
Cc: <users at openlayers.org>
Sent: Wednesday, September 02, 2009 3:34 PM
Subject: RE: [OpenLayers-Users] How Print openlayer Maps into pdf documents
If you are using geoserver you can create a wms request with format
application/pdf et volia!
Cheers Kris
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On
Behalf Of Alexandre Dube
Sent: Wednesday, September 02, 2009 5:29 PM
To: fsalas
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] How Print openlayer Maps into pdf documents
  Did you read http://trac.openlayers.org/wiki/Printing ?
  About eh ezpdf class extension, are you talking about this :
http://www.ros.co.nz/pdf/ ?  If so, that's the lib I used with
phpMapScript to accomplish some printing, but it supports WMS only and I
use Ext to make my form.  So take this example as a proof of concept
only.  See at :
    http://dev4.mapgears.com/wmsprint/
  MapFish has a much more better printing tool and it supports Vector
features printing.
Best of luck,
Alexandre
fsalas wrote:
> Hi all,
> I'm trying to print the current image maps into pdf documents
> using the  *EZPDF Class Extension,* but don´t work.
> some body know how i cant implement this.
> Thanks ,
> salas
> ___________________________________
> Dirección de Comunicaciones
> Grupo Empresarial GEOCUBA
> Este mensaje esta libre de virus.
> Revisado por Kaspersky Antivirus
> Definition count: 2365875 Definition date: 8/11/2009 SecurityPlus
> version: 3.0.5
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
Users mailing list
Definition count:  2492726
Definition date:  9/3/2009
SecurityPlus version: 3.0.5
