[OpenLayers-Users] remote kml file onto google projection
Marc Jansen jansen at terrestris.de
Thu Sep 3 15:54:14 EDT 2009
Hi Jonathan,
is the KML file located on the same server? If so, are you referencing
it by a full URL (e.g. 'http://www.example.com/file.kml') or via a
relative location (e.g. './file.kml')? I found the latter to be more
failsafe.
If the file is located under a different domain (e.g.
'http://data.example.com/file.kml' and your code lives at
'http://somethingelse.example.com') AFAIK there is no proper alternative
to using any sort of proxy.
Regards,
Marc
Jonathan Wolfe schrieb:
> Hi,
> I'm trying to overlay a remote kml file onto the google projection and I
> get: Access to restricted URI denied" code: "1012.
> When I use a local file, it works just fine.
> Because of security reasons, I cannot set up a proxy server like the FAQ
> suggests.  Does anyone know how to get around this?
> Thanks,
> Jonathan
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
