[OpenLayers-Users] How to change the display coordinates
Andreas Hocevar ahocevar at opengeo.org
Fri Sep 4 10:13:06 EDT 2009
Please provide a valid email address, and post follow-up questions to
the list.
You want me to show you how to calculate minutes and seconds?
Here are two functions from Mapbuilder  [1]:
   * Decimal to DMS conversion
  convertDMS = function(coordinate, type) {
    var coords = new Array();
    abscoordinate = Math.abs(coordinate)
    coordinatedegrees = Math.floor(abscoordinate);
    coordinateminutes = (abscoordinate - coordinatedegrees)/(1/60);
    tempcoordinateminutes = coordinateminutes;
    coordinateminutes = Math.floor(coordinateminutes);
    coordinateseconds = (tempcoordinateminutes - coordinateminutes)/(1/60);
    coordinateseconds =  Math.round(coordinateseconds*10);
    coordinateseconds /= 10;
    if( coordinatedegrees < 10 )
      coordinatedegrees = "0" + coordinatedegrees;
    if( coordinateminutes < 10 )
      coordinateminutes = "0" + coordinateminutes;
    if( coordinateseconds < 10 )
      coordinateseconds = "0" + coordinateseconds;
    coords[0] = coordinatedegrees;
    coords[1] = coordinateminutes;
    coords[2] = coordinateseconds;
    coords[3] = this.getHemi(coordinate, type);
    return coords;
   * Return the hemisphere abbreviation for this coordinate.
  getHemi = function(coordinate, type) {
    var coordinatehemi = "";
    if (type == 'LAT') {
      if (coordinate >= 0) {
        coordinatehemi = "N";
      else {
        coordinatehemi = "S";
    else if (type == 'LON') {
        coordinatehemi = "E";
      } else {
        coordinatehemi = "W";
    return coordinatehemi;
Now this is what you could do:
var mp = new OpenLayers.Control.MousePosition({
   formatOutput: function(lonLat) {
       var markup = convertDMS(lonLat.lat, "LAT");
       markup += " " + convertDMS(lonLat.lon, "LON");
       return markup
Regards,
Andreas.
[1]
http://svn.codehaus.org/mapbuilder/trunk/mapbuilder/lib/widget/CursorTrack.js
fsalas wrote:
> Thanks Andreas for your cooperations,
> but I have one doubt about How I use your function
> Is this possible send me one example about?
> Best Regards
> Salas
> ----- Original Message ----- From: "Andreas Hocevar"
> <ahocevar at opengeo.org>
> To: "fsalas" <fsalas at geocuba.cu>
> Cc: <users at openlayers.org>
> Sent: Friday, September 04, 2009 3:38 AM
> Subject: Re: [OpenLayers-Users] How to change the display coordinates
>> fsalas wrote:
>>> Hi , I need to change the display coordinates in degree minutes and
>>> second format example (NE 50 20´ 23´´ )
>> Just configure your MousePosition control with a custom formatOutput
>> function:
>>        var markup = "<your output markup here>";
>>        return markup
>> Regards,
>> Andreas.
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
> ___________________________________
> Dirección de Comunicaciones
> Grupo Empresarial GEOCUBA
> Este mensaje esta libre de virus. Revisado por Kaspersky Antivirus
> Definition count:  2495798
> Definition date:  9/4/2009
> SecurityPlus version: 3.0.5
Andreas Hocevar
