[OpenLayers-Users] Highlight on hover
François Van Der Biest francois.vanderbiest at camptocamp.com
Fri Sep 4 10:21:27 EDT 2009
On Fri, Sep 4, 2009 at 4:13 PM, François Van Der
Biest<francois.vanderbiest at camptocamp.com> wrote:
> Hi Steve.
> A potential reason is that the GML you're receiving does not use the
> same SRS as the one of your map.
> You may check this using FireBug.
OK, you're using MapServer.
Most probably, you've got no geometry in the GML response, but only bounds.
Are there some MapServer experts out there to tell us whether it's
possible to have geometries returned on getFeatureInfo ?
If yes, from which MapServer version is it possible ?
F.
