[OpenLayers-Users] Highlight on hover
François Van Der Biest francois.vanderbiest at camptocamp.com
Fri Sep 4 11:20:06 EDT 2009
I've never seen that before ;-)
MapServer considers your geometry column as an attribute !
Are your sure geom900913 is correctly referenced as the geom column
name for lim_admin.inddef_2006 in your postgis geometry_columns table
HTH,
F.
On Fri, Sep 4, 2009 at 5:06 PM, <Steve.Toutant at inspq.qc.ca> wrote:
> What I meant by continue button is in firebug there is no error but it
> happens that firefox stops (like a breakpoint) to the line mentioned. Then I
> click on the button (like Play button) to make the page continue
> loading...Just beside step into, step over, step out.
> This message doesn't appear on each request.
> First time I work with gml and vector layer so I can't see what is wrong.
> Here is the response.
> thank very much for your assistance
> Steve
