[OpenLayers-Users] different resolutions on x/y axis possible?
David Fawcett david.fawcett at gmail.com
Fri Sep 4 11:59:31 EDT 2009
If the data was served as a WMS, could one exploit the non-square
pixels 'feature' of the WMS spec?
What if one requested a 200 x 2000 px image with an extent (in local
coordinates) of 0 0 2 2000.  (I am not used to working with image
coordinates, so I may have the order mixed up).
Just a theory.
David.
On Fri, Sep 4, 2009 at 6:30 AM, Christopher
Schmidt<crschmidt at metacarta.com> wrote:
> On Fri, Sep 04, 2009 at 04:50:04AM -0500, Alex_vG wrote:
>> Is it possible to use for the x- and the y-axis of a layer different
>> resolutions?
>> I want to use OpenLayers to visualize a defect map of a steel strip. The
>> real dimension of the strip are appr. 2 meter x 2000 meter. That means a
>> real x/y Ratio of 1:1000. I've written a php-serverscript for rendering the
>> image-tiles by using the BBOX-Parameters for an WMS-layer.  For the mainmap
>> i want to use the ScaleLine and the MousePosition controls with the correct
>> values. In the OverviewMap i want to use a image which is compressed in the
>> x direction by 100 times so it has a x/y ratio of 1:10. The overview-image
>> has to be static without any zoom functionality. The pane-frame in the
>> overview-map has to show the actual extend of the main-map. I hope that i
>> can deal with this requirement using different x/y resolutions for my
>> OverviewMap. But i dont know how...
> I'm not aware of any way to do what you're asking for in OpenLayers.
> -- Chris
>> please have someone a good idea to help me with this task?
>> PS: sorry for the bad english... (answers in german are very welcome)
>> View this message in context: http://n2.nabble.com/different-resolutions-on-x-y-axis-possible-tp3578857p3578857.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Christopher Schmidt
> MetaCarta
> Users mailing list
