[OpenLayers-Users] How to change the display coordinates
Ivan Grcic igrcic at gmail.com
Sun Sep 6 05:01:14 EDT 2009
Hi all,
you could also check this
http://openlayers.org/pipermail/dev/2009-February/004389.html
Theirs function is a bit more advanced, as it takes correct decimal rounding
into account,
hope it helps,
cheers
On Fri, Sep 4, 2009 at 8:48 PM, fsalas <fsalas at geocuba.cu> wrote:
> Andreas , I test your solutions but openlayer
> show the standard coordinates format ej. -79.456,21.2365
> Why, the formatOutput don't affect ?
> map.addControl(mp);
> Regards,
> salas.
> ----- Original Message -----
> From: "Andreas Hocevar" <ahocevar at opengeo.org>
> To: "users" <users at openlayers.org>
> Sent: Friday, September 04, 2009 9:13 AM
> Subject: Re: [OpenLayers-Users] How to change the display coordinates
> Please provide a valid email address, and post follow-up questions to
> the list.
> You want me to show you how to calculate minutes and seconds?
> Here are two functions from Mapbuilder  [1]:
>   * Decimal to DMS conversion
>  convertDMS = function(coordinate, type) {
>    var coords = new Array();
>    abscoordinate = Math.abs(coordinate)
>    coordinatedegrees = Math.floor(abscoordinate);
>    coordinateminutes = (abscoordinate - coordinatedegrees)/(1/60);
>    tempcoordinateminutes = coordinateminutes;
>    coordinateminutes = Math.floor(coordinateminutes);
>    coordinateseconds = (tempcoordinateminutes - coordinateminutes)/(1/60);
>    coordinateseconds =  Math.round(coordinateseconds*10);
>    coordinateseconds /= 10;
>    if( coordinatedegrees < 10 )
>      coordinatedegrees = "0" + coordinatedegrees;
>    if( coordinateminutes < 10 )
>      coordinateminutes = "0" + coordinateminutes;
>    if( coordinateseconds < 10 )
>      coordinateseconds = "0" + coordinateseconds;
>    coords[0] = coordinatedegrees;
>    coords[1] = coordinateminutes;
>    coords[2] = coordinateseconds;
>    coords[3] = this.getHemi(coordinate, type);
>    return coords;
>   * Return the hemisphere abbreviation for this coordinate.
>  getHemi = function(coordinate, type) {
>    var coordinatehemi = "";
>    if (type == 'LAT') {
>      if (coordinate >= 0) {
>        coordinatehemi = "N";
>      else {
>        coordinatehemi = "S";
>    else if (type == 'LON') {
>        coordinatehemi = "E";
>      } else {
>        coordinatehemi = "W";
>    return coordinatehemi;
> Now this is what you could do:
> var mp = new OpenLayers.Control.MousePosition({
>   formatOutput: function(lonLat) {
>       var markup = convertDMS(lonLat.lat, "LAT");
>       markup += " " + convertDMS(lonLat.lon, "LON");
>       return markup
> Regards,
> Andreas.
> [1]
> http://svn.codehaus.org/mapbuilder/trunk/mapbuilder/lib/widget/CursorTrack.js
> fsalas wrote:
> > Thanks Andreas for your cooperations,
> > but I have one doubt about How I use your function
> > Is this possible send me one example about?
> > Best Regards
> > Salas
> > ----- Original Message ----- From: "Andreas Hocevar"
> > To: "fsalas" <fsalas at geocuba.cu>
> > Cc: <users at openlayers.org>
> > Sent: Friday, September 04, 2009 3:38 AM
> >> fsalas wrote:
> >>> Hi , I need to change the display coordinates in degree minutes and
> >>> second format example (NE 50 20´ 23´´ )
> >> Just configure your MousePosition control with a custom formatOutput
> >> function:
> >>        var markup = "<your output markup here>";
> >>        return markup
> >> Regards,
> >> Andreas.
> >> Andreas Hocevar
> >> OpenGeo - http://opengeo.org/
> >> Expert service straight from the developers.
> > ___________________________________
> > Dirección de Comunicaciones
> > Grupo Empresarial GEOCUBA
> > Este mensaje esta libre de virus. Revisado por Kaspersky Antivirus
> > Definition count:  2495798
> > Definition date:  9/4/2009
> > SecurityPlus version: 3.0.5
> Andreas Hocevar
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
Ivan Grcic
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090906/b6d67527/attachment.html
