[OpenLayers-Users] wrapDateLine issue
Brad Spencer brad at cubewerx.com.au
Sun Sep 6 20:15:59 EDT 2009
List,
When setting wrapDateLine: true on both the base layer and any WMS layer
request I still get a BBox generated from OL that is not valid - i.e the
BBox for a WMS request looks like the following:
BBOX=19871181.366475,-4754383.1586761,-19890389.245713,-4441297.0908636
So its generating a top right point that is a negative X coord which is not
valid.
I would have thought that if I have wrapeDateLine:true set that it would
generate a top right point that has a X coord value that is greater than the
bottom left X coord value.
Is this not the case? If so what is the workaround?
Cheers,
Brad..
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090907/33ca4fb4/attachment.html
