[OpenLayers-Users] map.RemoveLayer() does not work
sunny74 sb.ray at hotmail.com
Mon Sep 7 05:12:43 EDT 2009
Hi Leich,
Thanks for your reply.
It worked.
However I am having one problem.
I am removing one layer 'choice_features' using your code and then adding
one by the same name using
the following code:
 map.addLayer(new OpenLayers.Layer.GML("choice_features",
"XML1/FeatureGML.xml"));
This layer is being added from the file FeatureGML.xml in the folder XML1.
The GML file is created at run time and with every change in selection its
contents also changes.
But the selected feature on the map remains the same after the first
selection.
Only the first time does it show the feature correctly.After that it shows
the first one irrespective of the feature that is selected.
What wrong am I doing & how to set it right?
Thanks again.
Leich Tobias wrote:
> Hi, please try:
> var layers = map.getLayersByName('choice_features');
> for(var layerIndex = 0; layerIndex < layers.length; layerIndex++)
> 	map.removeLayer(layers[layerIndex]);
> Mit freundlichen Grüßen/Best regards
> Tobias Leich
> Softwareentwicklung & Systemadministration
> Service Management Center
> ADC KRONE Services
> tobias.leich at adckrone.com
> Mobil: +49 (0) 151 / 580 43 596
> Tel.: +49 (0) 3328 / 4590 512
> Fax.: +49 (0) 3328 / 4590 55 512
> Learn more about ADC KRONE at www.adckrone.com
> Rheinstraße 10B / 14513 Teltow / Germany
> ADC Services GmbH, Sitz Teltow, Amtsgericht Potsdam - HRB 19612 P
> Geschäftsführer: Fritz Lohr
> Ust-Id-Nr. DE 137227829
> -----Ursprüngliche Nachricht-----
> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
> Auftrag von sunny74
> Gesendet: Montag, 7. September 2009 07:14
> An: users at openlayers.org
> Betreff: [OpenLayers-Users] map.RemoveLayer() does not work
> Hi,
> I am trying to remove a layer using the RemoveLayer(layer,
>         setNewBaseLayer) function.
> The code is:
>  map.removeLayer(choice_features, false);
> It is only able to remove the layer "choice_features" the very first time
> it
> is created at PageLoad.
> But when the same layer is created the second time it is unable to remove
> it
> and throws javascript exception
> htmlfile: Invalid argument.
> So how to get it to remove the layer every time it is created.
> Awaiting solution.
> Thanks for your replies.
> http://n2.nabble.com/map-RemoveLayer-does-not-work-tp3595538p3595538.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://n2.nabble.com/map-RemoveLayer-does-not-work-tp3595538p3596265.html
