[OpenLayers-Users] Layer from GML loading only for the first time
sunny74 sb.ray at hotmail.com
Mon Sep 7 05:51:40 EDT 2009
Dear Friends,
I am having a query builder which allows an user to select one feature at a
time.
The geometry for this feature is then populated into a GML file format using
another xml.
So every time an user selects one feature the GML file is deleted and a new
one created with the geometry of the new feature.
Although GML file is created with every change in selection Openlayers is
unable to load the changed GML and show it on the map.
So openlayers is able to display the data from the GML for the first time
only. So from second and subsequent selection it shows only the first
feature on the map.
The code is:
map.addLayer(new OpenLayers.Layer.GML('choice_features',
"XML1/FeatureGML.xml"));
Is it a bug?
If not how to tackle the problem.
Thanks in advance.
View this message in context: http://n2.nabble.com/Layer-from-GML-loading-only-for-the-first-time-tp3596382p3596382.html
