[OpenLayers-Users] setCenter(), maxExtent is null error, Spherical Mercator Example documentation
Ted Spradley tspradley at snoogems.com
Tue Sep 8 14:51:15 EDT 2009
Ah!  Thanks much Chris!
Worked like a charm.  Obvious now that setCenter can not act with no layer
to act upon.
Thanks again, Ted S.
>       var proj = new OpenLayers.Projection("EPSG:4326");
>       var point = new OpenLayers.LonLat(-95.422899,29.737651);
>       map.setCenter(point.transform(proj, map.getProjectionObject()));
>       map.addLayer(layer);
^^ Add the layer first, then set the center.
-- Chris
>       map.zoomToMaxExtent();
>       </script>
>     </body>
> </html>
>                                               End html page
View this message in context: http://n2.nabble.com/setCenter-maxExtent-is-null-error-Spherical-Mercator-Example-documentation-tp3604502p3605331.html
