[OpenLayers-Users] OpenLayers.js with #1836 patch
Mike Adair madair at dmsolutions.ca
Wed Sep 9 09:28:46 EDT 2009
If I recall correctly when I was doing something similar, IE didn't
accept fractions in the symbol definition.  Scaling it up so that all
points were integers solved the problem.
Mike
Andreas Hocevar wrote:
> Thanks for the symbol defs, these still render incorrectly in IE indeed.
> #1836 needs more work. Patches welcome :-)
> Regards,
> Andreas.
> Philip Bruvoll wrote:
>> Thank you for the patch :)
>> I have just tried it out.
>> It seems that a symbol defined by [2,0, 4,5, 0,5, 2,0] now renders with
>> correct size,
>> but the position is still wrong (though it has changed). It also
>> calculates the center
>> wrong, because it moves when it is scaled up.
>> The symbol defined by [0.5,0, 10,8, 0,8, 0.5,0] still renders the same
>> incorrectly
>> way on IE8.
>> Does the two symbols above look the same on your machine with IE8 and
>> FF/Chrome/Opera?
>> Kind regards,
>> Philip
>>  > Date: Tue, 8 Sep 2009 15:13:32 +0200
>>  > From: ahocevar at opengeo.org
>>  > To: pbruvoll at hotmail.com
>>  > Subject: OpenLayers.js with #1836 patch
>>  > as promised. Rename OpenLayers.txt to OpenLayers.js.
>>  > Regards,
>>  > Andreas.
>> With Windows Live, you can organize, edit, and share your photos.
>> <http://www.microsoft.com/middleeast/windows/windowslive/products/photo-gallery-edit.aspx>
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
