[OpenLayers-Users] attaching a control to an external div
P Kishor punkish at eidesis.org
Wed Sep 9 20:39:33 EDT 2009
Per the docs for Control
"Controls by default are added to the map they are contained within
however it is possible to add a control to an external div by passing
the div in the options parameter."
which seems to be completely not like the source code at
http://openlayers.org/dev/examples/mouse-position.html
So, I have the following
<div id="map"></div>
<div id="coords"></div>
<script type="text/javascript">
// The following works, but the mouse position is displayed on the map
var ctrl_coords = new OpenLayers.Control.MousePosition();
map.addControl(ctrl_coords);
// The following does not work
var ctrl_coords = new OpenLayers.Control({div: "coords"});
ctrl_coords.MousePosition();
// The following also does not work
var ctrl_coords = new OpenLayers.Control.MousePosition({div: "coords"});
</script>
Pointers please, as I want to display the mouse position inside the
"coords" div. Does the documentation need to be updated as well?
Puneet Kishor
