[OpenLayers-Users] using openlayers as map interfacefordownloading pdf maps
Arnd Wippermann arnd.wippermann at web.de
Thu Sep 10 11:20:42 EDT 2009
Set extractStyles to false
and add the following style to your layer after layer creation. It should
also be possible to declare the style in the layer constructor.
var styleMapLabel = new OpenLayers.StyleMap({'default':{
    strokeColor: "#00FF00",
    strokeOpacity: 1,
    strokeWidth: 3,
    fillColor: "#FF5500",
    fillOpacity: 0.5,
    pointRadius: 6,
    pointerEvents: "visiblePainted",
    label : "${description}",
    //label : "name: ${name}, age: ${description}",
    fontColor: "red",
    fontSize: "12px",
    fontFamily: "Arial",
    fontWeight: "bold",
    labelOffsetX: 10,
    labelOffsetY: 10
    //labelAlign: "${align}"
map.layers[1].styleMap = styleMapLabel;
map.layers[1].redraw();
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von maning sambale
Gesendet: Donnerstag, 10. September 2009 09:13
An: OpenLayers-Users
Betreff: Re: [OpenLayers-Users] using openlayers as map
In doing this webmap I have sample here:
http://forest2002.essc.org.ph/test_map/
What I want next is to:
1. show kml layer label in the map for each polygon (mapsheet name and
number) 2. highlight color for the selected feature, either this one:
http://openlayers.org/dev/examples/highlight-feature.html
or this
http://gis.ibbeck.de/ginfo/apps/planwerk/planwerk_nordbahntrasse.asp
Any advise?
On Thu, Sep 10, 2009 at 12:08 AM, Arnd Wippermann <arnd.wippermann at web.de>
wrote:
> Hi,
> Have a look at
> http://gis.ibbeck.de/ginfo/apps/planwerk/planwerk_nordbahntrasse.asp.
> A click on a feature generates a link above the map for download of a pdf.
> Arnd
> [mailto:users-bounces at openlayers.org] Im Auftrag von maning sambale
> Gesendet: Mittwoch, 9. September 2009 12:41
> Betreff: [OpenLayers-Users] using openlayers as map interface
> Hi,
> We have prepared 1:250k sacle pdf topo maps for download.  I want to
> use openlayers as an interface for downloading.  The plan is to show
> the map boundingbox as a kml layer or georss over a slippymapy.  Each
> box would provide a link to the pdf download.  Any sample I can work with.
> Thanks in advance.
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
cheers,
maning
Users mailing list
