[OpenLayers-Users] Die Erlaubnis für den Aufruf der Methode XMLHttpRequest.open wurde verweigert - PGRouting
Andreas Hocevar ahocevar at opengeo.org
Sat Sep 12 03:00:46 EDT 2009
Mehmet Sirin wrote:
> Hi, thanks, It really seems to solve that problem! But now I got
> another one:
> Firebug needs to POST to the server to get this information for url:
> http://localhost/OpenLayers/examples/routing2.php?startpoint=890544.23042729%206847095.3929257&finalpoint=893983.89669951%206848777.0075477&method=SPD&srid=900913
> <http://localhost/OpenLayers/examples/routing2.php?startpoint=890544.23042729%206847095.3929257&finalpoint=893983.89669951%206848777.0075477&method=SPD&srid=900913>
> This second POST can interfere with some sites. If you want to send
> the POST again, open a new tab in Firefox, use URL 'about:config', set
> boolean value 'extensions.firebug.allowDoublePost' to true
> This value is reset every time you restart Firefox This problem will
> disappear when https://bugzilla.mozilla.org/show_bug.cgi?id=430155 is
> shipped.
The above comes from Firebug. You need to upgrade Firebug (and maybe
also Firefox) to avoid this message.
> When I push "Load Response": 890544.23042729<br>6847095.3929257<br><br />
> <b>Fatal error</b>: Call to undefined function pg_connect() in
> <b>/home/jars/workshop/OpenLayers/examples
> /routing2.php</b> on line <b>42</b><br />
This means that your PHP is compiled or configured without the
PostgreSQL module. If you have installed PHP the ubuntu/debian way, then
you have to install the php5-pgsql package (with apt-get, aptitude or
whatever you are using for that).
Regards,
Andreas.
> I think the last error is the main problem..
> Am 12. September 2009 00:12 schrieb Andreas Hocevar
> <ahocevar at opengeo.org <mailto:ahocevar at opengeo.org>>:
>     Hi,
>     you have to run your application off a web server, not the file
>     system.
>     Du mußt deine Anwendung auf einem Webserver installieren, statt
>     sie vom
>     Dateisystem zu starten, d.h. du brauchst URLs, die mit http://
>     beginnen
>     statt mit file://
>     lg
>     Andreas.
>     Mehmet Sirin wrote:
>     > Hi, I got an error like "No access for for method
>     XMLHttpRequest.open,
>     > when trying to calculate a route with pgrouting (data comes from
>     postgis).
>     > Hi, derzeit versuche ich mich am Tutorial
>     >  http://pgrouting.postlbs.org/wiki/WorkshopOL2.7andOSM bzw. habe
>     schon
>     > alle dortigen Schritte ausgeführt. Nun, wenn ich Start und Endpunkte
>     > setze, dann auf "Calculate Route" drücke, bekomme ich einfach gar
>     > nichts angezeigt. Firebug sagt das hier:
>     > verweigert
>     file:///home/jars/OpenLayers/lib/OpenLayers/Request/XMLHttpRequest.js
>     > Line 177
>     > verweigert
>     > open()()XMLHttpRequest.js (Linie 177)
>     > issue()(Object)Request.js (Linie 134)
>     > GET()(Object)Request.js (Linie 222)
>     > loadURL()("routing2.php?startpoint=889168.36391841
>     > 6851146.5554241&finalpoint=896888.50377383
>     > 6850611.4962262&method=SPD&srid=900913", null, null,
>     > displayRoute(response), null)Ajax.js (Linie 82)
>     > compute()index.html (Linie 199)
>     > onclick(click clientX=413, clientY=394)1YJQEPyB...BjA%3D%3D
>     (Linie 2)
>     > [Break on this error] this._object.open(sMethod, sUrl, bAsync,
>     sUser,
>     > sPassword);
>     > System: Ubuntu 8.04, Openlayers 2.8
>     > Hat jemand eine Idee zur Behebung dieses Problems? Ich bin
>     dankbar für
>     > jede Hilfe.
>     > MfG
>     > Mehmet
>     > _______________________________________________
>     > Users mailing list
>     > Users at openlayers.org <mailto:Users at openlayers.org>
>     > http://openlayers.org/mailman/listinfo/users
>     Andreas Hocevar
>     OpenGeo - http://opengeo.org/
>     Expert service straight from the developers.
Andreas Hocevar
