[OpenLayers-Users] using openlayers as map interfacefordownloading pdf maps
maning sambale emmanuel.sambale at gmail.com
Sun Sep 13 22:27:14 EDT 2009
Follow-up question, is it possible to increase or decrease fontSize
depending on the zoom level.  At low zoom levels, the text seems
crowded but too small at higher zoom level.
On Fri, Sep 11, 2009 at 3:12 PM, maning sambale
<emmanuel.sambale at gmail.com> wrote:
> Arnd,
> Thanks! This worked without a hitch!
> On Thu, Sep 10, 2009 at 11:20 PM, Arnd Wippermann
> <arnd.wippermann at web.de> wrote:
>> Hi,
>> Set extractStyles to false
>> and add the following style to your layer after layer creation. It should
>> also be possible to declare the style in the layer constructor.
>> var styleMapLabel = new OpenLayers.StyleMap({'default':{
>>    strokeColor: "#00FF00",
>>    strokeOpacity: 1,
>>    strokeWidth: 3,
>>    fillColor: "#FF5500",
>>    fillOpacity: 0.5,
>>    pointRadius: 6,
>>    pointerEvents: "visiblePainted",
>>    label : "${description}",
>>    //label : "name: ${name}, age: ${description}",
>>    fontColor: "red",
>>    fontSize: "12px",
>>    fontFamily: "Arial",
>>    fontWeight: "bold",
>>    labelOffsetX: 10,
>>    labelOffsetY: 10
>>    //labelAlign: "${align}"
>> map.layers[1].styleMap = styleMapLabel;
>> map.layers[1].redraw();
>> Arnd
>> -----Ursprüngliche Nachricht-----
>> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
>> Auftrag von maning sambale
>> Gesendet: Donnerstag, 10. September 2009 09:13
>> An: OpenLayers-Users
>> Betreff: Re: [OpenLayers-Users] using openlayers as map
>> Hi,
>> In doing this webmap I have sample here:
>> http://forest2002.essc.org.ph/test_map/
>> What I want next is to:
>> 1. show kml layer label in the map for each polygon (mapsheet name and
>> number) 2. highlight color for the selected feature, either this one:
>> http://openlayers.org/dev/examples/highlight-feature.html
>> or this
>> http://gis.ibbeck.de/ginfo/apps/planwerk/planwerk_nordbahntrasse.asp
>> Any advise?
>> On Thu, Sep 10, 2009 at 12:08 AM, Arnd Wippermann <arnd.wippermann at web.de>
>> wrote:
>>> Hi,
>>> Have a look at
>>> http://gis.ibbeck.de/ginfo/apps/planwerk/planwerk_nordbahntrasse.asp.
>>> A click on a feature generates a link above the map for download of a pdf.
>>> Arnd
>>> [mailto:users-bounces at openlayers.org] Im Auftrag von maning sambale
>>> Gesendet: Mittwoch, 9. September 2009 12:41
>>> Betreff: [OpenLayers-Users] using openlayers as map interface
>>> Hi,
>>> We have prepared 1:250k sacle pdf topo maps for download.  I want to
>>> use openlayers as an interface for downloading.  The plan is to show
>>> the map boundingbox as a kml layer or georss over a slippymapy.  Each
>>> box would provide a link to the pdf download.  Any sample I can work with.
>>> Thanks in advance.
>>> cheers,
>>> maning
>>> "Freedom is still the most radical idea of all" -N.Branden
>>> wiki: http://esambale.wikispaces.com/
>>> blog: http://epsg4253.wordpress.com/
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> cheers,
>> maning
>> Users mailing list
> cheers,
> maning
cheers,
maning
