[OpenLayers-Users] OpenLayer and the Spanish characters Ñ
Michael Shishcu micklesh at gmail.com
Mon Sep 14 04:31:18 EDT 2009
Hi, Paco
Can you check if you have set correctly NLS_LANG environment variable for
mapserver
for example, if you use mapserver with apache in cgi mode, add to your conf
file :
Set NLS_LANG ...
Regards, Michael
2009/9/2 Paco <fgines at hotmail.com>
> Hello list,
> I`ve problemas with OpenLayer/MapServer and the Spanish characters (Ñ).
> If I go to Mapserver directly with WMS there is no problem, but if I
> recuest
> the map with Openlayer he don’t show me the correct characters (España –
> Espa?a)
> I’ve tried with OpenLayers.Lang["es"];  o OpenLayers.Lang.setCode('es');
> Any suggestions of how to solve this problem.
> Thanks for your ideas?
> Paco
> WMS request
> http://hostname/cgi-bin/wms-file?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&
>                layers=toponimia&
> bbox=368850,4063000,375000,4067300&srs=epsg:23030
>                &format=image/png&width=400&height=400&styles=
> the mapfile  layer:
>        LAYER
>                NAME "toponimia"
>                METADATA
>                        "wms_title"     "Toponimia"
>                        "wms_srs"       "EPSG:23030"
>                END
>                PROJECTION
>                        "init=epsg:23030"
>                END
>                TYPE annotation
>                STATUS on
>                LABELMINSCALEDENOM 1
>                LABELMAXSCALEDENOM 5000
>                CONNECTIONTYPE oraclespatial
>                CONNECTION "table/pasww at db"
>                DATA "SDOPUNTO FROM (SELECT POSICION, TEXTO, ROTACION,
> SDOPUNTO
> FROM TOTPNMVIAL_T
>                        INNER JOIN TPNMVIAL …….
>                        WHERE …….) USING NONE"
>                DUMP TRUE
>                CLASS
>                NAME "Textos cc"
>                        TEXT ([TEXTO])
>                        LABEL
>                                TYPE truetype
>                                FONT arial
>                                SIZE 8
>                                POSITION cc
>                                ANGLE [ROTACION]
>                                COLOR 25 25 112
>                        END
>                END
> END
> The Script:
> layer = new OpenLayers.Layer.WMS( "Cartografia", url,
>    {layers: "toponimia"}, {singleTile: true, ratio: 2.0 });
> var options = { maxExtent: maxBounds,
> scales: [50000,25000,10000,5000,2000,1000],
> projection: "EPSG:23030",  units: "m",
> controls: [     new OpenLayers.Control.Navigation(),
>                new OpenLayers.Control.PanZoomBar(),
>                new OpenLayers.Control.ScaleLine(),
> new OpenLayers.Control.LayerSwitcher(),
>                new OpenLayers.Control.KeyboardDefaults()
>        ], numZoomLevels: 6};
> map = new OpenLayers.Map( 'map', options);
> map.addLayers([layer]);
> var lonLat = new OpenLayers.LonLat( "${X}", "${Y}");
> map.setCenter(lonLat,4);
> and in the header:
> <meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090914/d79af136/attachment.html
